Home > General Chat > More BRIGHTER Lights
do any one have different bulbs in there H4 lights?? as the 55w - 60w bulbs as standard are rubbish at when one is enjoying the back road at night!
I know you can be more powerful bulbs, are these ok for the normal mini wiring loom??
giallofly
Member #: 164
The Stig..
Newport Pagnell
I used to run 80/120's on my golf with no promlems with the stanard loom.
What about all these people that wire spots into their full beam?
good point about the spot lights*wink*, and these 80/120's must have been well bright:), just the job.
Mini Stevo
Member #: 239
Somerset
Suprised you can actually see things when driving your car Mini Williams. You must be good at them magic eye thingies. *happy*
Cheers, Stevo
pot_dan
Member #: 326
bradford, west yorks
i hear verry good things about phillips vision plus i think they are called, not heard a bad thing about them.
Dan
Arno
Member #: 233
Beugen, Netherlands
I use H4 100/120 on all my cars, it gives not double the light but it makes a huge difference.
The point is that on cars that use normally duplo bulbs, the H4 may generate to much heat and therefore may not survive as long as expected in a nowadays car.
try it you will like it.
pete
Member #: 275
bonie scotland
a good earth makes the diference
Cheers that's a good help.
now off to get some.
evolotion
Member #: 83
Glasgow, Scotland
personaly id whack a relay in the lighting circuit if you dont have one(believe later mini looms did) as iv burnt thro to many headlight switches with the normal lights.
Denis O'Brien.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Yep i agree. I have melted the switch with just the normal 55w bulbs. I got some of those 50% brighter jobbies (zennon or something) for the lotus and was very impressed with the difference.
http://www.twin-turbo.co.uk
Got some of the 'white' lights from Demon Tweeks. More expensive than the Xenon ones, but WOW!!!!
Can't remember the number, buit they were around ?18 the pair.
evolotion i could be lucky there as i have a later loom, so fingers crossed.
cheers ben and dave something more to think about., just for fun i've just looked in the demon tweeks cat and there is a pair of H4 bulbs in there for ?40! hell that's not cheep!
billydude
Member #: 48
Leicester
I'd still advise a relay as the pink rover relay and wireing got very hot in mine with 90/100 watt bulbs *blush*
I found with a relay and a decent earth mine are loads brighter than while relieing on the pink relay *wink*
"relay as the pink rover relay and wireing got very hot in mine "
this is interesting mate as my pink one gets bloody hot to, but on normal wattage bulbs, and some times it smells like it's burning a little, car sticks and it's is coming from that large rely.
billydude
Member #: 48
Leicester
mines cool as a cucumber now my headlights are relayed
the only downside is spagetti junction and relays under the bonnet now *laughing*
Looks like relays it is then:)
so it will take the pressure off the pink one then i guess.
billydude
Member #: 48
Leicester
yup and the upside is power direct from the battery, altenator connection on the starter
with the standard wireing running high beam and a relay running main beam . high beam is dimmer than main beam *laughing*
are i better get my wire out then, cheers:)
MajicMini
Member #: 72
I'm using 100 Watt Rally bulbs (they look like blue light from some angles), they are very bright. I don't have any relays, just standard wiring loom and I haven't had any electrical problems.
billydude
Member #: 48
Leicester
try hooking them direct to the main power lead and watch them get brighter *wink*
as from the main power lead relayed they'll get 14volts when the cars running without the power drain of running through the loom *wink*
