Home > Help Needed / General Tech Chat > Firing Order, No Start
Right then my pedigree chums, its another (it wont start thread) ive been trying to fire the car over the last few days but to no avail, had no spark turned out to be bad points, had no fuel turned out id piped the bloody regulator in backwars ( *Jester* however, i know im getting fuel as my plugs are wet, the left 2 are slightly sutty so they are sparking, the right 2 arent, so i thinking either the timing 180deg out or, i have the leads on wrong.
Is this the correct order?
Also all i keep getting is a very deep boom up the exhaust, im assuming this is just unburnt fuel being dumped.
The 3 is the bottom left lug, is obscured by the TM Logo
Miguel
mike, when no 1 piston is at tdc on compression, the rotor arm will be pointing at no1 cyl, look in the cap and se if it corresponds to any one of the contacts , by the look of the cap ,it looks like it shoud sit with the leeds pointing upwards, as a guide, this would put no1 contact at approximatly the 2 o'clock position and pointing at no 1 cyl.
carl
It could be pointing at #4 as well :)
Yes carl this is how the cap sits mate, im sure i checked the rotor arm, but you know me!
Ill double check it tonight. And make sure that piston no1 is on the up stroke.
On it's firing stroke is the key here. TDC & firing stroke.
thats why i said compression, lol,
also mike have you swung the dizzy whilst cranking it over, this will give you an indication if you have thew drive in wrong.
carl
Edited by fastcarl on 11th Jul, 2008.
How so carl? I understand the bit about swining *wink*
How would it give an indication?
carl
because you can move it a good way round to see if your a long way out or in the ball park. you can swing a long way you know *smiley* depends on the length of your leads mind.
But yeah, rocker off, get it on compression to to TDC on no.1 then just work it from there.
Make note of the direction of rotation of the rotor arm *wink*
anti clockwise irrc. The engines turn backwards... i think.
Yes, ill check over this, im awaiting an in line Fuel Pressure gauge which ill mount in the engine bay, this way ill know for sure if my pumps good ect.
Ill double check the timing
then check the carb.
And so on and so forth.
Mike
Edited by MikeRace on 11th Jul, 2008.
Just to clerify, my leads are correct no??
1342 anti clockwise. all depends on where you have number one.
they look right though if you have 1 in the right place.
An a series will normal start and noticeably fire on 2 cylinders so i'm guessing your not right at all.
I had got the cap off carl and he had scraped a no1 next to a lug. So if its wrong blame carl!
depends where you put the dizzy and the dizzy drive though! *wink*
