| Home > Show Us Yours! > My New Engine | |||||||
11th Jul, 2008 at 02:09:41pm
I've finally cracked and decided to move on from the A Series.
11th Jul, 2008 at 02:13:20pm
Swheeettt! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
11th Jul, 2008 at 02:34:00pm
holy shit!!! this could be worth watching!!! |
11th Jul, 2008 at 02:34:43pm
Are you gunna run a spazmatic box then? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
520 Posts Member #: 2093 Post Whore Grenoble, France |
11th Jul, 2008 at 02:48:18pm
What's that Paul ?
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
11th Jul, 2008 at 02:54:59pm
paul maybe a WW2 spitfire engine of 1952 BHP Would be better ....lol
11th Jul, 2008 at 03:03:11pm
On 11th Jul, 2008 alpa said:
What's that Paul ? I see a short 90 v6, so likely an odd firing. One cam, so 12v. Why bother yourself with such a complex thing ? A modern jap 2L 4cyl would certainly perform better ? It's a very modern Nissan V6. Same bottom end as the 300ZX but with the more robust 12v heads/cams. All the aftermarket twin turbo cranks, rods, pistons etc fit. Potentially more horpsepower than I will ever to able to use. I plan to use the Autobox as it will be able to change gear quicker and more consistantly than my driver. The top drag cars use auto boxes. Biggest problem could be the gearbox ECU. An old mate of mine uses the exact same setup in his car, so I have some experienced help to guide me. Must go, there are men in white coats at the door. Edited by Paul S on 11th Jul, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
11th Jul, 2008 at 05:11:05pm
And the engine ECU ? Is the engine odd firing ? Does MS support odd-firing ? std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
11th Jul, 2008 at 05:15:27pm
And the engine ECU ? Is the engine odd firing ? Does MS support odd-firing ? It's 60 degree even fire - no problem. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
12th Jul, 2008 at 01:17:02pm
twin turbo, v6 sounds very nice :) do it Drives
21st Dec, 2008 at 11:15:55pm
I'm guessing this is still sat in the corner of the workshop waiting for the day when it will roar into life? Isambard Kingdom Brunel said:
22nd Dec, 2008 at 04:17:27pm
On 21st Dec, 2008 Rob H said:
I'm guessing this is still sat in the corner of the workshop waiting for the day when it will roar into life? ha ha , yes it is still where it was when I took the photo, but plans change as I'm sure that you are aware. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Dec, 2008 at 05:50:42pm
I know how it is.....Not enough time in the day Paul. :)
On 19th Jan, 2010 wil_h said:
315 Posts Member #: 3013 Senior Member Epsom Surrey |
22nd Dec, 2008 at 07:33:16pm
is the gearbox strong enough though??
22nd Dec, 2008 at 07:42:07pm
On 22nd Dec, 2008 DD_Racing said:
is the gearbox strong enough though?? i mean a twin turbo v6 3 litre should be putting out a good solid 350 hp to 400hp on 15psi why not go front engine rearwheel drive and use a american box like a th350 or a 727 tourqflyte???? That was about as far as I got, then gave up on the idea entirely
22nd Dec, 2008 at 07:44:11pm
On 22nd Dec, 2008 Paul S said:
but plans change as I'm sure that you are aware. Don't I know it. Isambard Kingdom Brunel said:
