| Home > Help Needed / General Tech Chat > No oil Pressure | |||||||
108 Posts Member #: 654 Advanced Member |
11th Jul, 2008 at 04:16:38pm
Hi, just finished reassembling the engine after it blew it's head gasket, but now when im cranking it with the ht leads off it won't build oil pressure, any idea's why this would be? the oil level is fine and i've left it cranking long enough but still nothing, it's only been stood for a couple of week's so im confused,
559 Posts Member #: 2775 Post Whore Aberdeen |
11th Jul, 2008 at 04:51:15pm
Sound like the pump is dry / air locked. Try removing the oil pressure relief valve and pour in some oil (quite a lot ) if you can then put the valve back in and crank it over. Hey presto (hopefuly) |
11th Jul, 2008 at 04:59:55pm
cheers lockfast i'll give it a go, out into the rain once again then... |
11th Jul, 2008 at 05:17:13pm
Try taking the plugs out also, you'll be able to crank the engine alot faster. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
11th Jul, 2008 at 05:36:29pm
failing that remove the banjo union from the block the pipe what goes to the oil filter housing and pour oil in there in the block
Edited by BENROSS on 11th Jul, 2008.
11th Jul, 2008 at 05:39:18pm
try putting it in 4th, rolling it backwards, whilst feeding oil down the filter feed hole
11th Jul, 2008 at 08:35:10pm
Joey you druggy! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Jul, 2008 at 09:03:45pm
yeah found a use for my old shooter (im trying to cut down lol) "Turbo's make torque, and torque makes fun"
12th Jul, 2008 at 12:01:06pm
too much time smacked of your tits on hypoid eh? On 28th Aug, 2011 Kean said:
