| Home > Help Needed / General Tech Chat > Only two gears ! | |||||||
141 Posts Member #: 2408 Advanced Member surrey / ewell area. |
14th Jul, 2008 at 11:16:27am
Am i right in assuming i have put the selector rod in 180 degrees out seems like i only have two gears and hardly any neutral .:$ |
14th Jul, 2008 at 11:34:57am
baseplate on the gear lever assembly in wrong way round? turbo 16v k-series 11.9@118.9 :)
14th Jul, 2008 at 02:04:00pm
Ive never had the base plate off could it be that ? is it possible to spin the selector rod 180degrees with no pin in thereby not being able to select gears.? |
14th Jul, 2008 at 02:21:47pm
if you havnt touched the gearbox (removed teh end covers from teh diff) you should only be able to move the selector rod within its window of operation. can you select gears wit hthe lever disconected and mole grips on teh selector rod? turbo 16v k-series 11.9@118.9 :)
14th Jul, 2008 at 02:42:09pm
As per evolution but, even if you have had the selector mechanism apart, it is impossible to get the selector shaft 180 out - the window of operation is determined by the interlock tube (which the selector shaft can only fit inside one way) and an actual window in the tube which the detent tube/ball/spring push into (behind the diff end/side cover).
Edited by Rod S on 14th Jul, 2008. Schrödinger's cat - so which one am I ??? |
14th Jul, 2008 at 03:13:24pm
Sorry to keep asking questions but if the rod change unit had been disconnected from engine would it be possible ive done anything backwards, i had the short shift lever in before and it was fine tried putting it back on this time and the alloy housing of the lever doesnt go down far enough onto housing of the unit to screw up properly ive heard about taking off bottom plate and spinning the eye? |
14th Jul, 2008 at 03:20:58pm
If it is one of those cheap short shift levers, that would be your problem.
14th Jul, 2008 at 03:21:01pm
Take the gearstick out and look which way the eye is? Is the eye right at the top or at the bottom? It should be at the bottom.
Edited by MikeRace on 14th Jul, 2008. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Jul, 2008 at 03:23:32pm
it`s a genuine kad lol with lift up reverse plunger and the eye is at the bottom ! damn was hoping it was that anything else to check ? |
14th Jul, 2008 at 03:27:53pm
Have you tried selecting gears at the gearbox? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Jul, 2008 at 03:33:45pm
yep i did it when we were running up the engine just to see if we could get them all , its weird i seem to get two gears forward and backwards perfectly but no neutral atall? i put the standard lever back in couldnt fit it properly as the pin for the clamp isnt there but it felt easier to move about could be just because its a new box? |
14th Jul, 2008 at 03:49:30pm
Had the gearbox been rebuilt (even if not by you) ??? Schrödinger's cat - so which one am I ??? |
14th Jul, 2008 at 03:50:30pm
yeah but as isaid it seemed fine at the time got all gears. anything else i could try? |
14th Jul, 2008 at 03:55:50pm
On 14th Jul, 2008 greymini78 said:
i had the short shift lever in before and it was fine tried putting it back on this time and the alloy housing of the lever doesnt go down far enough onto housing of the unit to screw up properly This is your problem. Take it off again and find out why it is not seating properly. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
14th Jul, 2008 at 03:57:56pm
When Mike said " have you tried selecting all the gears at the gearbox" you said you only got two forward (and reverse).
14th Jul, 2008 at 03:59:53pm
Cheers for your replies guys will give it a go will also get the unit off and put a punch in the roll pin slot and go through the gears that way to make sure nothings happened in transit :) |
14th Jul, 2008 at 04:01:56pm
yeah it was tested with grips at the engine with linkage disconnected which was fine then driven home in van and put in car then tried in situ with linkage etc. the first test had all gears this was without linkage second time was at my garage with everything attached
Edited by greymini78 on 14th Jul, 2008. |
14th Jul, 2008 at 04:35:32pm
Do u think its worth taking the whole assembly and starting again checking for anything that could be catching? could i try it without bottom plate on or is this not advised? |
14th Jul, 2008 at 05:16:28pm
I cant see how it can make difference, start by using a standard gear stick. Then go to the box end of things. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
16th Jul, 2008 at 01:09:25pm
Right quick update guys it works spot on with the standard stick , and i mean spot on . to be honest the only reason i bought the kad was because it looked nicer and had less throw but to be honest with this new box it feels nice with a standard stick, and also like alot of peeps on here have said it only really makes a difference if track racing etc |
16th Jul, 2008 at 01:10:49pm
P.S Thanks to everyone on the forum who has helped me get this little bugger back on the road , your help is very appreciated i will post some piccies soon. |
