| Home > Help Needed / General Tech Chat > mpi head mods and 1.7 rockers on mpi | |||||||
14th Jul, 2008 at 10:16:06pm
sorry, not a turbo question but
14th Jul, 2008 at 10:29:41pm
a well ported head will add a good 10 to 15 % to the power
14th Jul, 2008 at 10:36:04pm
id prefer the cam change, reality is that i dont have time at the moment. afraid its just bolt on parts for now.
14th Jul, 2008 at 10:36:47pm
why would you not use the 1.7s? surely they would be better than 1.5s performance wise with a standard cam?ta |
14th Jul, 2008 at 10:37:37pm
The standard ECU is pretty useless when it comes to changing cam profiles from what i've read. Thats why the upgrade kits for the injection Minis usually have high lift rockers instead of a cam change, so you get increased breathing through higher lift but without changing the cam characteristics.
14th Jul, 2008 at 10:41:19pm
i know it wont make that much power, a nice 75 bhp and nice bit of tourqe would be nice. final drive change would be ideal, as i said i really dont have time for this at the moment. so its just the bolt on parts and head work for now. would skimming the head and raising the cr be benificial to the performance as well as porting and polishing? |
14th Jul, 2008 at 10:43:49pm
What's the compression ratio now ? |
14th Jul, 2008 at 10:46:49pm
standard whatever that is.
14th Jul, 2008 at 11:18:56pm
raising the cr ratio to around 10.5:1 max and Some sensible head work as phil said
15th Jul, 2008 at 12:59:20pm
what is the difference between a mpi head and other a series heads? had a quick look, all i can see is the alternator bracket. can a non mpi head be drilled and tapped for mpi use? thanks |
