Home > Help Needed / General Tech Chat > fuelling issues
tuktuk
Member #: 1675
hello guys
the only way i can get fuel through the carb is to blow down the overflow pipe and immediately block it off. once thats done and the engine is turned over i can see fuel pulse up through from where the needle normally sits(dashpot ect is off at the minute).
as soon as i let off the overflow pipe the fuel is sucked back down into the carb.
i checked the breather pipe on the tank and it was jammed up against the rear seat so i released that but its still the same ?
car is a N/A 1330 with hif44 carb
lockfast
Member #: 2775
Aberdeen
What pump are you using? And is it pumping fuel when disconnected from the carb?
So there is nothing wrong.
Fuel will only come out the nozzle when the velocity over the bridge creates a negative pressure.
tuktuk
Member #: 1675
its a new mechanical type pump. definately got fuel to the carb, its getting it past the carb which is the problem.
im gonna put everything back together now and see if it fires up again
Turbo Tel
Member #: 588
Delaware, USA
If you have the SU piston out and look down into the jet hole and shake the car you should be able to see the fuel level just below the jet. If you can't, then the float chamber level is too low and this probably means that the float valve is plugged or the float is mis-adjusted.. I would suspect a bad valve.
Pressurising the float chamber just forces the fuel up the jet hole, which is the only place it can go..
Edited by Turbo Tel on 15th Jul, 2008.
Richie
Member #: 628
I would be inclined to suggest float falve gunged up, you ran the ank dry not so long ago and you are not using any inline filters, i cant think of anything else buddy. when you brought it to me it was running on three cylinders, i believe you and Jordie have checked the coil etc and it is ok, so i am stumped buddy.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
tuktuk
Member #: 1675
well i done a compression test
from the rad
11 - 13 - 12 - 11 i dunno what thats measured in but it came in the green on all of them.
im guessing thats good enough to get it running ?
i definately have a spark on all 4. atleast they all spark when resting on the slam panel.
richie give me that weber sitting on youre bench lol
JordieNE
Member #: 1591
Prudhoe, Newcastle
compressions are fine. You allow for a couple lee way. Defo a spark at all plugs, the engine doesnt seem to like those NGK's so try using the champion ones when it does run again.
We;ve tried two carbs, same problem. I believe tom is trying a 3rd, so will see what happens.
tuktuk
Member #: 1675
yep, il try this 3rd carb... if it wont go on this one il use the rebuild guide and sort one of them out.
tuktuk
Member #: 1675
im now getting fuel... using the hif44 carb that was originally on the car when it was running as sweet as a nut all of 2 weeks ago
yet it wont even try to start ?
i think timing is my next approach ? but i really cant see that moving as the dizzy is pretty dam solid
Turbo Tel
Member #: 588
Delaware, USA
What made you decide that the fuel was OK? are the plugs getting wet? if so and you have a spark then next is to check the firing order.
Get#1 on the compression stroke ( tdc and both rocker arms UP) and make sure the dizzy rotor arm points to the wire that goes to #1 spark plug then anticlockwise from there wires 3,4,2 should be connected in that order..
If that doesn't work you need to decide what you have touched since it last run..
Terry
tuktuk
Member #: 1675
plugs getting wet yehh.
right il give that a go...
tuktuk
Member #: 1675
got hold of a timing light and it was miles out, put it somewhere near and it really tried to run at one point but as soon as the engine tries to go, the starter motor lets off the flywheel and the engine dies... its as if it needs to turn it over a few times and get it running before it disengages
atleast we know what the problem is now
tuktuk
Member #: 1675
new starter on it, timing set, different coil(cheers richie), new plugs and a mess with fuelling and it runs like a dream !
took it out and had a blare around the streets and made the last few weeks of fiddling worth it :)
massive thankyou to jordieNE for all the help
Richie
Member #: 628
I may need the other two back buddy, have not decided if mine is going to be started on MJ or a dizzy yet.
glad you got it squared away
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
tuktuk
Member #: 1675
no bother buddy :) il pop them down sometime
