Home > Help Needed / General Tech Chat > New crank and pistons...what cc
bertieboo
Member #: 1613
N. Ireland
Ok im thinking of putting an 110 crank in a 998 with =120 pistons from minisport australia, what cc would that give me?
cheers
The 998 pistons have a higher compression height than the 1100.
Hence, it would give you pistons sticking out the deck by +0.150".
bertieboo
Member #: 1613
N. Ireland
If I used 1100 pistons then would that work? Minisport aus do them in +60
Edited by bertieboo on 15th Jul, 2008.
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Yep, using 1098 pistons would be ok. The only difference between a 998 and a 1098 is the pistons and crank. Well, they had different heads from the factory but they are interchangeable
EDIT: Thats how my build is put together. A 998 donor engine with Hypatec 1098 +0.060" pistons and a 1098 crank
Edited by GaryOS on 15th Jul, 2008.
On 30th Apr, 2010 Rod S said:
Gary's description is best
Yes, but you can only get them up to +0.060".
I was looking into this the other day for some reason.
I posted a chart giving capacities and combustion chamber volumes for common overbores, including 1098s a few days ago.
1100 Turbo build with Hypatecs..
http://home.online.no/~lyngset/1300.cfm
If you look hard, you can see where the block came from:
Edited by Vegard on 15th Jul, 2008.
bertieboo
Member #: 1613
N. Ireland
My dad has an 1100 engine from a moris minor, would that have the same crank from the 1100 mini engines?
No, the in-line cranks have a different end for flywheel mounting.
bertieboo
Member #: 1613
N. Ireland
ah right. I remember a fella telling me that you could get a 998 out to 1215cc? I cant remeber exactly what it was but it used a 1100 crank and hillman imp (?) pistons.......cant remember if they were the right pistons, can any body correct me?
Edited by bertieboo on 16th Jul, 2008.
GaryOS
Member #: 2810
Dublin, Ireland
Yup, a 1098 with Imp +0.040" pistons gives you 1251. I think Vizard talks about it in the "Big Motors" section of his book
