| Home > Help Needed / General Tech Chat > Biting point / fuel pressure | |||||||
141 Posts Member #: 2408 Advanced Member surrey / ewell area. |
19th Jul, 2008 at 03:48:19pm
Sorry to ask two questions at once but with regards with biting point where should it be on pedal mines at the top of pedal travel so too high? would prefer it lower down. its a verto slave with pre verto clutch,also do u have to use the return spring?
19th Jul, 2008 at 03:56:10pm
fuel pressure won't rise on a suck through setup dude.
19th Jul, 2008 at 05:25:31pm
On 19th Jul, 2008 greymini78 said:
its a verto slave with pre verto clutch,also do u have to use the return spring? Yes, return spring required on pre-verto... Bit of a problem with the Verto slave as it doesn't have the required tag. Without it, you cannot set the travel on the adjuster bolt (the 1/4" one at the top of the arm). Verto doesn't need travel setting, but pre-Verto does. Schrödinger's cat - so which one am I ??? |
19th Jul, 2008 at 05:29:31pm
cheers for the answers guys. ive heard some people use verto slaves but i presume its easier just to get the correct slave? and in regards to the regulator i dont need one relly then? |
19th Jul, 2008 at 05:37:26pm
you need a regulator yes, but just to set the pressure at 3.5psi, the pump will kick out a lot more than that. On 20th Oct, 2015 Tom Fenton said:
