Home > Help Needed / General Tech Chat > Honed or rebore?, help needed for engine rebuild please.
MarkGTT
Member #: 1194
Shropshire.
Hi, what do you guy think, does this need a rebore or honed?
pics not great, let me know if you need any more. :)
thanks, Mark.
Edited by MarkGTT on 20th Jul, 2008.
Socket set in the background looks nice :)
MarkGTT
Member #: 1194
Shropshire.
thanks, would help if i knew what i was doing with them tho.. :)
Gavin Wakely
Member #: 793
Just an estimation based on the pic's, but I would guess a hone and new rings, but the real way is to put a new ring in the bore and measure the gap (sorry don't know the measurement)
That's of no use. Go out and have a proper measure. Then measure pistons. If the skirt clearnace is too big = new pistons and rebore time.
Pistons are USELESS in this case, so is the piston ring method.
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
use your nail to feel the gap between the top cylinder (were the rings never go)and just under, if there is any wear you'll feel it easily( make sure to have cleaned coke before and do it all around the bore , if it just need a hone you'll feel no or very light gap under your nail.
your pics are not good enough, what are these mark in the bore? oil water or scoring?
MarkGTT
Member #: 1194
Shropshire.
Thanks all,
doesnt feel like allot of ware, just very slight scoring.
i don’t have anyting accurate enough to measure the skirt clearance.. however i will sort so i can make sure.
Usually there is most wear at BDC ringland. This is where you have to measure, not at the top. However, this gives you an idea. If there's even a hint of ridge there, it's usually rebore time.
For every % of leakage in the cylinder, there is equal hp-loss.
All you need are some feeler gauges.
Pop a piston out, remove the rings and place it in the bore upside down, the measure the gap between the piston and the bore with the feeler gauges. Remember to measure the skirt at 90 degrees to the grudgen pin as this is where it is widest. Also rotate the piston and move it up and down measuring the gap as you go to check if the cylinder is round and the side are parallel.
Edited by Rob H on 20th Jul, 2008.
