Home > Help Needed / General Tech Chat > Reducing engine movement
johnnysti
Member #: 2480
Hi all
After fitting my sc i had to remove the engine steady that went to the thermostat but now when acc or braking i get alot of engine rock. Ive got the one fiited that connects to the block by the clutch and the one at the bottom that connect to the front of the subframe. Im also running a flip front so not sure if this matters.
Does any one know if there is someone that makes a steady that goes where the ultimate one went to fit 'around' the charger?
Thanks
Johnny
feature=mhum
Coupe
Member #: 2178
Leyland, Lancs
I just went with solid engine mounts and a rose jointed engine steady - now I get no engine movement at all.
Bit noisy and lots of vibrations mind!
hows the car been i saw you about amonth ago with the hazzards on stoped on the phone?
solid mount and custom steady :)
Avonbar do a fancy one that fixes to the waterpump and the bulkhead, dont know what your belt run is like but it might be worth a look
johnnysti
Member #: 2480
Was that at north star round about? If so, the weber was leaking fuel. Its off to slarks tomorrow to get the seal on the clutch sorting to stop the oil getting on the clutch!!
feature=mhum
