| Home > Help Needed / General Tech Chat > gear selector shafts -selector forks, help | |||||||
21st Jul, 2008 at 02:58:14pm
is there a special knack to get the gear selector shaft to engage with the selector fork mechanism? i have just changed the final drive, so had to disconect this to lock the gearbox up. i cant seem to get the groves on the shaft to go where they should.
21st Jul, 2008 at 03:42:27pm
Yes, but it's very hard to put in words...
21st Jul, 2008 at 04:25:11pm
as retired said, make sure you all in neutral in all gears and dont forget reverse as this is the usaul suspect, slao so sometimes the selector hits on the bell levers to which can be a problem but a bit of twisting and shoving normally gets it sorted. always looking for them bigger bunches of bannanas |
21st Jul, 2008 at 10:42:09pm
cheers chaps. was in reverse. silly arse! |
