Home > Help Needed / General Tech Chat > MG Metro camshaft identification
Sorry, another question :)
Apart from putting it in an engine and measuring timing with a DTI, is there any definitive identification between a standard 1275 (slot drive) cam and the MG Metro one?
The table in Vizard seems to say there is a groove after the third lobe on a standard one and not on an MG one but the table is a bit of a mess....
Does a complete lack of any markings make it an MG one or does it just make it unknown???
I can't go by the engine number as its obviously been swapped (A series number on an A plus block).
I was going to PartEx it for a PH2 but if it is an MG one, that seems a bit of a waste!
lockfast
Member #: 2775
Aberdeen
Hi
I have one that is an MG one and I cant see any markings on it either. But i know 100% that is the mg one. I have it out of a car if you want send a pm with your email address and I can send you photos to compare if that helps?
On 23rd Jul, 2008 lockfast said:
.....I can send you photos to compare if that helps?
Thanks for the offer but I don't think the difference in the lobes is enough to see.
The fact that yours doesn't have the groove though is encouraging.
There is a machined groove 1/4" wide between two of the lobes. Which lobes they are, I dont recall.
On 10th Sep, 2007 fastcarl said:
i have one with a groove between the first two lobes,no 1 ex and no1 inlet.
just in case nothing works out
carl
Thanks Dave,
That makes it even more confusing !!!
Vizard says the standard 1275 (slot drive) cam has the groove after the third lobe (so between No. 2 inlet and No. 2 exhaust). Nowhere in his table does he say any of the cams have a groove after the first lobe. Mine has no grooves !!!
I guess I'll have to put it my lathe (quicker than putting it in the engine) with a protractor and DTI it to be certain....
Rod.
Edited by Rod S on 23rd Jul, 2008.
Every MG cam I have seen, has had the 1/4" wide groove. It is not the normal 'groove' that one occasionally sees on other cams that is around 2mm wide - it is a clearly visible 1/4" wide rectangular section groove.
Thanks Dave and thanks to Lockfast (I asked him to email me some pics after all).
Vizard is wrong !!! (table on pages 284/285 of the yellow book) and mine is a plain 1275 cam.
I also found some very good identification photos on ML Motorsports site.
At least I can part Ex it for an Avonbar PH2 now without worrying I'm throwing away the next best.
