| Home > Help Needed / General Tech Chat > IDLE MIX ADJUSTMENT | |||||||
141 Posts Member #: 2408 Advanced Member surrey / ewell area. |
23rd Jul, 2008 at 12:44:09pm
Hello everyone mot on thurs! need to check mixture b4 just to get it there though . I bought a colour tune kit but Im not that confident with it . is there another way of initially setting up the carb ie screw the mixture screw right in then 3 turns back something like that ? just worried as its a new engine and im driving bout 10 miles to centre. what should i be aiming for regards to % 3? at idle stu gurr profiled needle on old 1275 bini kit how far out would this needle be now its a 1293 with dished pistons no comp plate etc, he said it should be ok for running in but `ok` doesnt give me much confidence . |
23rd Jul, 2008 at 01:08:59pm
I'm in the same situation.
Edited by theoneeyedlizard on 23rd Jul, 2008. In the 13's at last!.. Just |
23rd Jul, 2008 at 01:18:19pm
on the HIF "out" is lean
23rd Jul, 2008 at 01:18:31pm
fair point !! lol. |
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
23rd Jul, 2008 at 01:49:39pm
yeah, take it very gentle and listen for pinking. Mixture at idle shouldn't do any damage i wouldn't have thought...
23rd Jul, 2008 at 01:59:09pm
Ive got a problem with my mixture at the moment.
23rd Jul, 2008 at 09:05:48pm
So is there a way by taking the dash pot off? i saw a topic on here the other day but cant find it now |
23rd Jul, 2008 at 09:13:28pm
grey, the tickover mixture screw is down the back of the carb on the drivers side pointing toward the driver from down its hole.
23rd Jul, 2008 at 09:17:51pm
yeah cheers i know where the screw is , i just read a post saying u can take off dashpot and check where the valve in the centre is in terms of initial setting up of the carb after a rebuild , any ideas? i just cant remember how high the brass thingy should be. |
23rd Jul, 2008 at 09:26:05pm
TBH ive never looked at that, always just gone by fiddling with the screw. On 28th Aug, 2011 Kean said:
23rd Jul, 2008 at 11:29:43pm
On 23rd Jul, 2008 mini13 said:
grey, the tickover mixture screw is down the back of the carb on the drivers side pointing toward the driver from down its hole. rich mini, i'd try thinner dashpot oil,or maybe just changing it. as the dash pot oil becomes thicker in the cold it increases the initial richness when you depress the throttle as it stops the dashpot rising as quick. Aha thanks for the advice!! I did a search a week or two ago and decided to use DOT4 brake fluid in the dashpot! Shall I swap it out for some normal engine oil? All i've got is 20w 50 Sorry for the hijack by the way:$ |
24th Jul, 2008 at 12:49:15am
on the HIF "out" is lean with the engine idling wind it out til it starts to become uneven, then wind it back a turn. That works for me, it would not be far off if you set the idle that way, Use 20w50 oil (Genuine SU dashpot oil is 20weight) the rest is down to the shape of the needle and nowt you can do there by twiddlin the adjusters! Terry Edited by Turbo Tel on 24th Jul, 2008. website:- http://www.terryhunt.co.uk
24th Jul, 2008 at 12:50:34am
cheers for the replies guys . here tel have u seen my clutch post ?any ideas |
