Home > FAQ / Knowledge > EXCELLENT (and cheap) online nut/bolt/fittings supplier
http://www.namrick.co.uk/
A well known and respected company!!!
Lots of UNF and metric sizes, in zinc plated and Stainless!
They are also the best place I've found for 'p-clips' for attaching your fuel lines to your mini. Rubber lined, zinc or stainless (you shouldn't use plastic ones for your fuel line - especially if under the car), they are also the 'short' ones, where the fixing bolt is near to the actual tube/pipe being secured...
They are also realistic about P&P, sending stuff under 1kg by 1st class post from ?1.50 to ?4.00!!! Some mini specialists could learn from that....
Edited by turbodave16v on 10th Aug, 2004.
