| Home > Help Needed / General Tech Chat > 73.5 mm ofset bore please help | |||||||
7 Posts Member #: 2816 Junior Member |
23rd Jul, 2008 at 10:34:33pm
Shout out to all you big bore engine builders.
24th Jul, 2008 at 12:08:56am
Yes the gap will be smaller
Edited by Sprocket on 24th Jul, 2008. On 26th Oct, 2004 TurboDave16v said:
24th Jul, 2008 at 08:19:43am
On my block, I only went to 73mm (1360) and although Vizard says offsetting isn't required at 73mm, I did what Sprocket says - I measured it all very carefully first, including measurements of a new BK450 gasket and I then worked out the optimum position of each bore.
Edited by Rod S on 24th Jul, 2008. Schrödinger's cat - so which one am I ??? |
24th Jul, 2008 at 09:35:18am
You want bto see that middle bore wall with 74mm pistons! IIRC its only 2.4mm thick, the fire ring of the AF460 gasket is flush with the bores! On 26th Oct, 2004 TurboDave16v said:
