| Home > Help Needed / General Tech Chat > Oil temp sensor | |||||||
186 Posts Member #: 538 Advanced Member Frimley, Surrey |
23rd Jul, 2008 at 10:44:18pm
Right then lads.
23rd Jul, 2008 at 10:45:16pm
Mine's in the sump, speedo end. |
23rd Jul, 2008 at 10:48:41pm
Ok, I'm guessing that requires the engine and gearbox to be removed? |
103 Posts Member #: 2314 Advanced Member cumbria |
23rd Jul, 2008 at 11:27:31pm
Go on e bay and buy a oil filter sandwhich plate. It goes between ur oil filter and housing. Ther absolute superb. They have 4 take off holes. I have my oil temp, pressure sensors in it as well as the turbo oil feed. Its 1 of the best items ive bought. Makes the job look like it grew there. |
24th Jul, 2008 at 09:49:03am
On 23rd Jul, 2008 turbogt said:
Go on e bay and buy a oil filter sandwhich plate. It goes between ur oil filter and housing. Ther absolute superb. They have 4 take off holes. I have my oil temp, pressure sensors in it as well as the turbo oil feed. Its 1 of the best items ive bought. Makes the job look like it grew there. Have you found one that works on the Mini oil filter housing? Link please :) On 13th Jul, 2012 Ben H said:
24th Jul, 2008 at 06:16:42pm
My mate has one on his 1380, seems to work ok. Not sure where it came from though.
24th Jul, 2008 at 06:39:03pm
Is this sandwich plate the one from Autodials of Wakefield,presently on Ebay?.If so does it fit without modification,please ?. |
24th Jul, 2008 at 10:31:47pm
It comes from an e bay shop called auto guages. The item number is 360072473190. You need the 3/4 UNF fitting. It needs no mods at all to fit and the sensors of mine screwed right in. Its a fantasticly made item as well. I was very impressed with it and no leaks at all. |
24th Jul, 2008 at 11:02:47pm
Thanks a lot |
25th Jul, 2008 at 09:58:09am
So this fits a Mini..
25th Jul, 2008 at 07:08:56pm
Yep thats the one. Fits like a glove8-) |
25th Jul, 2008 at 07:26:36pm
On 25th Jul, 2008 Vegard said:
Phil. did you weld a boss on your sump? No, just found a thick bit, drilled & tapped. :) |
25th Jul, 2008 at 08:42:46pm
Phil. did you weld a boss on your sump? No, just found a thick bit, drilled & tapped. :) The speedo bit as per Benny? Edit: On 23rd Jul, 2008 Turbo Phil said:
Mine's in the sump, speedo end. DOH! Edited by Vegard on 25th Jul, 2008. On 13th Jul, 2012 Ben H said:
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
1st Jan, 2009 at 07:42:34pm
On 24th Jul, 2008 turbogt said:
It comes from an e bay shop called auto guages. The item number is 360072473190. You need the 3/4 UNF fitting. It needs no mods at all to fit and the sensors of mine screwed right in. Its a fantasticly made item as well. I was very impressed with it and no leaks at all. Just digging out an old thread, is this the same as the item described above (as the item number is no longer valid) from "autodials" rather than "auto gauges". And is this a recomended option for oil pressure, temp, and turbo oil feed? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=390020032348 |
155 Posts Member #: 246 Advanced Member Cumbria |
1st Jan, 2009 at 08:31:03pm
Edited by 8PortChris on 1st Jan, 2009. |
1st Jan, 2009 at 08:36:00pm
use it for temp and pressure, but don't use it for the oil feed as you will hae unfiltered oil going to the turbo. On 28th Aug, 2011 Kean said:
1st Jan, 2009 at 11:14:29pm
hope this helps ..... http://turbominis.co.uk/forums/index.php?p=vt&tid=4569
2nd Jan, 2009 at 09:39:18am
On 1st Jan, 2009 BENROSS said:
hope this helps ..... http://turbominis.co.uk/forums/index.php?p=vt&tid=4569 i did read all that but im not confident enough to start drilling and tapping! i'll take the easy way out and get the sanwich plate i think. |
2nd Jan, 2009 at 12:25:33pm
can i ask what thread are the sensors boss's in that sandwich plate?
4th Jan, 2009 at 12:17:13am
i'll have to check what they are , i can't remember at the moment
