Home > Help Needed / General Tech Chat > Twin fuel tanks - What about the return?
killer_chiller
Member #: 325
Quick question - How do you go about plumbing two fuel tanks, when using a fuel pump with a return?
Is there a box of tricks that checks the fuel level via a sender, then changes a valve?
Any ideas
think if your balance pipe is big enough and you plumb the return to both tanks you should be ok.
Nick
Member #: 154
Midlands
you could do it the same way that jukka has. he used a t piece for his fuel return. i think ive got a picture and a diagram he sent me before as i haven't modded my tank for a return, but i've only got the one tank.
Nick
Member #: 154
Midlands
Hope he doesn't mind me posting them up but they helped me out a fair bit anyway
Carl
Member #: 95
liverpool-on-sea
or fit a dummy right hand filler neck like what i did *tongue*
killer_chiller
Member #: 325
Cheers for the pic and diagram.
ha ha minime got one allready!
evolotion
Member #: 83
Glasgow, Scotland
Iv a twin tanked turbo sat here(not mine :( ), its set up with a big fat balance pipe, which goes into the filter then pump etc, and a return going into one tank.
Denis O'Brien.
