| Home > Technical Chat > turbo kit | |||||||
19 Posts Member #: 2965 Member scotland |
28th Jul, 2008 at 01:28:17pm
my car is smoking, not too bad but bad enuff, had it in too get repaired, the guy said he replaced a couple of seals and said i need to use the car more,coz he said the seals are hardening,is he talking shite, well its still the same no change, but he said if its still smoking it will probably be the turbo, where do i get a repair kit etc and roughly how much, oh and see when i put my foot down it doesnt sort of decelarates instead of accelerate any help will be greatly appreciated |
28th Jul, 2008 at 01:45:09pm
... and breathe. lol!
In the 13's at last!.. Just |
28th Jul, 2008 at 04:54:01pm
On 28th Jul, 2008 theoneeyedlizard said: ok m8 cheers and about the set up bit its just been built by the previous owner who built it up so a would say no
... and breathe. lol! It will be either the valve guides, valve stem oil seals or oil seals on the turbo. Have a look in the boost hoses. If there's oil in there it's the turbo, if not it one (or both) of the others. The 'deceleration' will probably be down to fueling. Has it been set up properly? |
28th Jul, 2008 at 05:02:18pm
Get it on a rolling road as soon as possible.
28th Jul, 2008 at 05:18:25pm
Who built it and who "repaired" it ???
28th Jul, 2008 at 05:34:59pm
On 28th Jul, 2008 theoneeyedlizard said: a think the smoke is like a grey blue colour it smokes when ye boot it a wee bit an it smokes on idle,and was goin to get it on a rollin road
Get it on a rolling road as soon as possible. What colour is the smoke? When does it occur? |
28th Jul, 2008 at 05:36:17pm
On 28th Jul, 2008 retired said: to be honest a dont think he changed seals he said he also put in a oil conditioner
Who built it and who "repaired" it ??? Any garage (or even an amatuer mechanic) would first do a compression test, or better still a leakdown test, before "replacing a couple of seals". Only then will you get an idea of what's leaking the oil to burn in the exhaust. The seals in the turbo are piston ring type seals, not rubber, so don't go hard with age (although they can obviously wear) so what seals was he/she talking about ??? Turbo repair kits are available on eBay but you need to mark it carefully when taking it apart to maintain the balance (asuming someone before you hasn't already screwed it up hence the oil useage) or know a proper turbo reconditioner who can re-balance it for you. |
28th Jul, 2008 at 05:39:16pm
On 28th Jul, 2008 stu1318 said:
to be honest a dont think he changed seals he said he also put in a oil conditioner Oil conditioner???
28th Jul, 2008 at 05:45:37pm
did he look like this ??
28th Jul, 2008 at 05:49:14pm
28th Jul, 2008 at 05:50:20pm
On 28th Jul, 2008 theoneeyedlizard said: probably so m8 On 28th Jul, 2008 stu1318 said:
28th Jul, 2008 at 08:47:46pm
OK, after the humor, can your "really good mechanic" (who couldn't be arsed at the time) actually do a compression test or, better still, a leakdown test.
quote]
