Home > Help Needed / General Tech Chat > Dont wont to start ...Help...
Giancooper
Member #: 2402
HI guys, I'n tryng to start my engine, it's a blow setup supercharger whit intercooler
but don't wont to start....
The problem? Fuel....
The pump it's ok, the fuel go in to the regulator and than in the carb , and not in to the engine....
I think is the piston because the float is ok, but the piston is not stuck....
The carbis a n/a convert to turbo whit dashpot seal, the yellow spring and needle bdd.
Someone can help me??
Edited by Giancooper on 28th Jul, 2008.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I think I have worked out what you are asking. Are you foreign?
Why are you sure it is the fuel and not the ignition? What have you done to decide it is the fuel side?
http://www.twin-turbo.co.uk
Kean
Member #: 341
aka T2clubby
South Staffs
As Ben said, have you checked for a spark and the timing in the right place?
Or is it too much fuel and flooding the plugs?
El Potter
Member #: 2169
Malta (Ex. Scotland)
Ben seeing his Forum name,I'd say he's italian.Also his english appears to be italianized.
Sorry can't be more useful*happy*
Warning:Stig in Training
Giancooper
Member #: 2402
Yes I'm Italian..... Sorry for the bed english *happy*
The problem is the fuel because if I put it on the manifold from the dump valve tube the engine strat, bu they die 5 second later.....
ok,
here is a thread with all the carburetor conections, it is worth checking they are correct.
http://www.turbominis.co.uk/forums/index.p...7478&lastpost=1
also, it is worth checking that the gasket between the plenum and carburetor is not blocking off any holes.
