| Home > Help Needed / General Tech Chat > fiesta hoses adapter | |||||||
112 Posts Member #: 1613 Advanced Member N. Ireland |
30th Jul, 2008 at 07:45:04am
I was thinking about just using the standard mini hoses and getting an adapter made to run the fiesta brakes....does anybody what the mini fitting that usually goes into the caliper is called? And the fiesta end is m10x1 as far as i know. |
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
30th Jul, 2008 at 08:33:48am
it has a banjo type fitting you will want pretty long ones, i recall when i did the fezzy conversion i had to try three different sets of hoses otherwise you wfind when on full lock it pulls the pipe and problems will occur. as for the copper pipe meeting the flexi. it is metri rathar than imperial my local motor factors made me some piping with metric ends on for the hoses, which was not expensive i might add. Edited by Richie on 30th Jul, 2008.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
30th Jul, 2008 at 12:18:13pm
Definately go for banjo bolts for the calipers. I recently changed the hoses on the British Open to ones with banjos as they were starting to split due to the kink it puts in the pipe. The likes of Merlin Motorsport will make you a set for very little money. Note with banjo bolts you may need a thick copper washer to get them to seal properly as the thread on the calipers is slightly recessed. Isambard Kingdom Brunel said:
30th Jul, 2008 at 12:23:52pm
Second that. Banjo bolts in the caliper is a Godsend! On 13th Jul, 2012 Ben H said:
30th Jul, 2008 at 11:15:44pm
sorry forgot to add about the copper washers too, Nice one Rob.
![]() 85 Posts Member #: 2234 Advanced Member Palm Beach Gardens, Florida |
31st Jul, 2008 at 06:43:27pm
over here I get that stuff from Pegasus Racing, decent prices. The hoses they sent were Goodridge, the adapter was made by Longacre
82 Posts Member #: 939 Advanced Member |
31st Jul, 2008 at 08:32:53pm
you can use metty 4 pot caliper hoses ok |
