Home > For Sale > Turbo Bits. modified head, recon carb, recon turbo, exh system etc
JordieNE
Member #: 1591
Prudhoe, Newcastle
Right, after stripping the head off to fit my new modified head, i have found that a bore of my engine has been damaged and also a single piston damaged. I cannot afford a new block, rebore and a new piston, so decided to break the turbo project and fit a 1275cc instead.
The following are for sale....
T3 turbo, no play in shaft, doesn't smoke, recently reconditioned before I bought it by avonbar. Comes with adjustable bleed valve and braided oil feed. 150 ono
Maniflow turbo downpipe, elbow bend with flexible ball joint. £40 ono
Cylinder head....Modified to 28cc chambers, polished chambers, 180lb double valve springs, new valve stem seals, valves reconditioned and lapped in. Inlet ports lightly polished for better fuel atomisation. Exhaust ports opened and so it flows better. Head is flat, painted red and ready to bolt on. Never used since the work was carried out last week. 200 ono (Suit turbo or supercharger)
Reconditioned turbo HIF44 carb, mint condition, works lovely, looks like new, polished dashpot. 100 ono SOLD
Turbo inlet manifold 25 ono SOLD
Rsturbo intercooler 20 ono SOLD
selection of 2inch silicon pipe, 2 90deg polished stainless bends. contact me for what i have.
Dump valve and silicon hose with dumpvalve take off. 35ono
Boost guage. smoked type, lights up nice. 20 ono SOLD
Turbo fuel pressure regulator 30 ono
3x omega +0.40 10cc dish pistons with new pins and rings. offers.
Its all gotta go as i need to buy stuff for my N/A 1275cc engine. I cannot afford a rebore for my current block and a new set of pistons, so im better off using a 1275cc engine i had in the lockup with my gearbox etc from this engine.
Based in newcastle area. Most items can be sent by courier pretty cheaply. Jordie
Edited by JordieNE on 5th Aug, 2008.
mokle
Member #: 2488
Edinburgh
PM'd about boost guage
Tony
emt
Member #: 888
newcastle upon tyne
pm about silicone hoses
have you got any pics mate?
Richie
Member #: 628
Cant believe ure seling up Jordie is the block shagged ? i will give you an A+ block even got some metty turbo rods and pistons !?
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
minimatt
Member #: 2417
Pmed About the head il have it if u can nock a bit off to cover travel :)
JordieNE
Member #: 1591
Prudhoe, Newcastle
PM's replied to.
Richie, its too late, built a 1275cc engine to replace it. Ive spent loads on this and its gone wrong. I cant even be bothered with a std metro turbo engine, its always something when i need the car to go somewhere. So 1275cc standard is the way for now, then probally a 1380 n/a weber'd engine.
JordieNE
Member #: 1591
Prudhoe, Newcastle
Bump. Needs to go so i can get my car on the road again.
N.a Twink!
JordieNE
Member #: 1591
Prudhoe, Newcastle
Good idea. Maybe next year.
miniboo
Member #: 2253
Las Vegas, Brit in the States
i'll be able to help you with parts for that twink conversion!!
JordieNE
Member #: 1591
Prudhoe, Newcastle
any interest before ebay?
JordieNE
Member #: 1591
Prudhoe, Newcastle
Pics
Head
Carb, inlet manifold and modified plenum
Turbo rising fuel regulator
Turbo unit itself, with 10psi actuator and bleed valve
Goes on ebay tomorrow with a buy it now price if no one is interested.
