| Home > Help Needed / General Tech Chat > Oil in cyclinder 1 | |||||||
![]() 338 Posts Member #: 1911 Senior Member Swindon |
2nd Aug, 2008 at 02:36:24pm
Hi peeps. Mostly stated as above but its a strange problem as it has had me wondering non stop for last two days with constant searching on here. Basically trying to fit twin 1" 3/4 carbs and this is where it started from.
2nd Aug, 2008 at 02:57:54pm
alright fella, have you check all your valve stem seals? and have you been able to have a look down into the chambers with a torch? if so can you see anything? what is the conditon of all the plugs like? i have a spare head mate if you cant to try it to see if it is the head thats fooked. it is a big valve head as well but needs a little clean up.
2nd Aug, 2008 at 03:05:31pm
I'm thinking valve stem seals but if you see the amount of oil sitting on the piston, its impossible for it to suck that much through there surely. Your talking a puddle of oil. I'm just taking carbs off atm, still in search for 7/16 socket in case this head does come off, bloody arp bolts. Noticed that the moly lube wasn't used either. argh bloody MED.
2nd Aug, 2008 at 03:07:43pm
I would either get both carbs working and see if the "oil" is still there after a run or put the single carb/manifold back on and again, see if it's still there after a run.
2nd Aug, 2008 at 03:12:15pm
rings fooked from running lean?? could that pass that amount of oil up? Drives
2nd Aug, 2008 at 03:43:59pm
if rings where stuffed then compression would be down wouldn't it? |
2nd Aug, 2008 at 04:05:46pm
On 2nd Aug, 2008 quinton said:
if rings where stuffed then compression would be down wouldn't it? Exactly, and why would this suddenly happen when you changed to twin carbs which you know aren't working..... get the original single carb back on, or get the twins working, then see what happens. With the head still on, you may be looking at what you think is oil on top of the pistons down through the spark plug holes, but it may just be a fuel/oil mix because the mixture was all wrong on those two cylinders as you say one carb wasn't working.... Schrödinger's cat - so which one am I ??? |
![]() 514 Posts Member #: 2169 Post Whore Malta (Ex. Scotland) |
2nd Aug, 2008 at 05:07:01pm
But Rod he said it's the right carb which was working and cylinders 1 and 2 are on the right.
Warning:Stig in Training
2nd Aug, 2008 at 05:09:06pm
1" 3/4 twins sound a fair old size for a 1380?
2nd Aug, 2008 at 05:26:37pm
Right just got the twin carbs off and the oil has come from the right carb. I have got my breathers connected to the carb's as one way of releaving crankcase pressure as it is really high.
2nd Aug, 2008 at 05:52:43pm
I suppose they could suck oil,if the breathers are chucking out quite a bit of the stuff. Warning:Stig in Training
2nd Aug, 2008 at 06:14:02pm
sure its not damper oil from overfilling? |
2nd Aug, 2008 at 06:26:27pm
OK, from your additional information.... if you have the crankcase breather connected to the "right" carb - I assume you mean right looking from the outside front, ie, 1&2 cylinders - and you have a known problem with crankcase pressurisation, AND the "left" carb (cylinders 3&4) isn't fuelling right, so you've offset the mixture to the right and it's pulling oil in, then...... yes, expect oil in 1&2 cylinders.
Edited by Rod S on 2nd Aug, 2008. Schrödinger's cat - so which one am I ??? |
2nd Aug, 2008 at 06:51:33pm
simple way to test, just vent the breather to air |
2nd Aug, 2008 at 08:25:26pm
I dont think I have a high crankcase pressure, just running the breathers on a air filter might cut a few pipes away in the engine bay but it does make everything around it black and I cant be arsed with the cleaning all the time so I thought I'll put it back to how it was plus this might decrease the crankcase pressure if there is any.
3rd Aug, 2008 at 11:47:17am
right all sorted, cheers for that chaps. Was plugs in the end, bosch super 4's, dunno why I got them lol. Anyways run's sweet now so thanks for all the help along the way. :) |
3rd Aug, 2008 at 02:30:19pm
Good to hear that mate.
3rd Aug, 2008 at 03:37:30pm
at least you have some good plugs after we finnaly realised which grade you needed lol :) hope the tune up goes well Drives
