Home > 998cc > Basics
Boycie
Member #: 3298
Right correct me if i have anything wrong but these are some of the things that i have found i will need inorder to build a 998 turbo.
High pressure fuel pump
Fuel pressure regulator
Air Intake pipe
Oil Cooler
Turbo downpipe
Clamp on air type filter
Decent exhaust system
Decent radiator have heard the 2 core type radiator to be good ?
Braided Turbo Oil feed pipe
Is there anything else im forgetting ? or is there anything on the above list thats not needed ?
Im building the 998 from scratch so what will i need to look at components wise like Pistons as im sure the standard set up is no good
Ben H
Member #: 184
Melton Mowbray, Pie Country
Well that is a start. I do think in the FAQ we need to ad an explicite list of every thing that is needed. I know it is all there, but sometimes it is not obvious to find.
Anyway, the things I can think of are:
Turbo (essential to choose the right one for your needs)
Turbo carb
Inlet manifold
Turbo exhaust manifold
As for the speck of the engine have a look here:
http://www.twin-turbo.co.uk/The%20Spec.html
and
http://www.turbo-mini.com/62147.html
Boycie
Member #: 3298
Right ive been looking around and i aint found much so where can i try to collect these bits ? ebays a bit useless atm so is it worth ringing around salvagers ?
