Home > Help Needed / General Tech Chat > wheel alignment
philc
Member #: 1346
bromsgrove
Sorry to trouble you again just your knowledge and advice has always been spot on.
Approx 18months ago i have my suspension setup, camber and wheel alignment, since then i have taken my subframe off and put it back on.
The other week someone said one wheel is further than the other, I have been back to the chap who set it up origanally, put it on the ramps and measured from back wheel to front, it was a considerable gap between each side approx 3/4 inch.
I told him that i had taken my subframe off and thats all I have touch in respect of suspension etc.
He pointed out the where the subframe tower goes fits into the tunnel, the gap on one side was bigger than the other.
I have spent today adjusting this gap and put a small block behind each tower to keep in line.
I have measured the wheel base again, there is a 15mm difference from the one side.
Will he be able to rectify this by adjusting the tie bars or could it possibly be something else?
