| Home > Help Needed / General Tech Chat > N/A not running right. UPDATE 04/08/08 | |||||||
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
2nd Aug, 2008 at 08:01:16pm
Ok so I replaced the headgasket on my daily drive yesterday. It went between 1 and 2 in quite a big way.
Edited by stefaz on 4th Aug, 2008. On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
2nd Aug, 2008 at 10:10:14pm
what else did you have done to the head eg skimmed, valves re-seated, etc. have you checked the mixture and timing |
2nd Aug, 2008 at 11:00:59pm
Did you replace the manifold gasket and have you checked that it is torqued down properly since you ran the engine ?. |
2nd Aug, 2008 at 11:07:58pm
I have not had the head skimmed.. Been playing with the mixture a bit, trying to get it a bit richer - timing is set at 8 degrees btdc.
4th Aug, 2008 at 09:40:22pm
tightened everything. It is running on all four cylinders. It does idle, but dies pretty quickly, I was going to try leaning it off a bit and have a play with the timing again when I'm off tomorrow On 23rd Oct, 2009 sim_ou_nao said:
