Home > Help Needed / General Tech Chat > Flywheels & Timing gears
Mattlad
Member #: 1871
Chesterfield, Derbyshire
I'm just starting to buy goodies for my project, Im after super lightweight components. should I go for a KAD Alloy flywheel (3.7kg) Backplate (1.14kg) or Avonbar Super lightweight flywheel (2.1kg) backplate (1.4kg) anyone had experience with either of these products??
Which would be the best set of timing gears to go for? again lightweight and good quality.
Thanks Matt
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
Swiftune do a stupidly light flywheel too and its cheaper than the KAD one. Isn't MED the only company to do timing gears for the A-series?
On 30th Apr, 2010 Rod S said:
Gary's description is best
Or PM fastcarl as he makes alloy flywheels, as used on the DON!
Swifty does a timing chain set with an alloy centre for the cam sprocket. Its very light and pretty cheap too. I have one aswell as his very very light flywheel
Paul
Mattlad
Member #: 1871
Nice one cheers, them swifttune onea look really NICE!! shame you dont see them!
These were the timing gears I was looking at from MED
http://www.med-engineering.co.uk/product_d...50&vlang_id=394
Matt
