| Home > Help Needed / General Tech Chat > head gaskets, knock detection | |||||||
![]() 21 Posts Member #: 293 Member |
12th Aug, 2004 at 12:14:55am
just wondering is it a good idea to use two headgaskets to lower CR ?? any known problems with doing that? |
12th Aug, 2004 at 12:27:01am
I wouldn't have thought that it's the best idea! but I've never tried it so I'd only be guessing.
12th Aug, 2004 at 12:39:34am
what are "det cans" .. iv heard these talked about before.
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
12th Aug, 2004 at 08:17:54am
knock sensors can be bought check out american racing shops's web sites , or monty turbo had a knock sensor on the block - looked like a temp sensor ,screwed in the front- maybe still buy it from rover and make your own with a light ?
12th Aug, 2004 at 08:25:13am
pinking is differnt to detonation thou...
AlexF |
12th Aug, 2004 at 08:59:47am
I thought I read something about reducing CR by using 2 head gaskets in A.G. Bells forced induction performance tuning but can´t find it now!
12th Aug, 2004 at 09:53:28am
Its an awful idea...
AlexF |
969 Posts Member #: 47 Post Whore Not very sunny swanage |
12th Aug, 2004 at 11:12:04am
ikts an afwull idea! hasnt stopped me doing it though! not too sure how long it will last, but so long as it does a few miles, i will be a happy bunny! And on the 7th day........... God created turbochargers! |
12th Aug, 2004 at 11:38:17am
even with two gaskets the best you'll get is an extra 2-3cc's
AlexF |
14th Aug, 2004 at 07:21:16pm
the af 470 also used as a turbo head gasket has 3.8 cc in it the copper asbestoes/ steel type has 4.1 cc ,my supercharged mini was running a spacer plate to reduce compression further still, and that blew (running lean after a hose come off the inlet),quick repair at the track(goodwood) was three head gaskets to get me home , its still running at 11 psi ! its not ideal but sometimes these things work ,its been back on the rollers and is still chucking out 152 bhp @5900 rpm with these three gaskets on untill the new steel spacer plate is ready (used with an af470 either side ) its still working !!
14th Aug, 2004 at 07:54:53pm
well if three gaskets work your nutter driver will be fine then i guess:) Best 1/4 mile 13.2 seconds @116 mph
62 Posts Member #: 198 Advanced Member |
14th Aug, 2004 at 10:04:21pm
Pinking is caused by over advanced ingnition timing, with the mixture being ignited before the piston is at TDC, they say the piston rattle sin the bore as it goes over TDC,
15th Aug, 2004 at 12:52:17am
Stu, why use the af470, and not the bk450? On 15th May, 2009 TurboDave said:
15th Aug, 2004 at 10:41:31am
OK lets get a few things sorted:
AlexF |
