| Home > Help Needed / General Tech Chat > Exhaust manifold leak | |||||||
69 Posts Member #: 1457 Advanced Member Bristol |
4th Aug, 2008 at 07:59:28pm
Hi all. My exhaust manifold has started leaking from the centre (where the manifold touches the head). The gap can be seen by just looking at the manifold! Have any of you had any problems similar to this? Could my manifold be warped? Or should i try just replacing the gasket? Cheers |
4th Aug, 2008 at 09:19:11pm
its common for them to warp slightly.
4th Aug, 2008 at 09:40:59pm
yes, as iain says you have to file away the two outer and use a straight edge to check your work
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
4th Aug, 2008 at 10:15:12pm
ive had this problem
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
4th Aug, 2008 at 11:05:30pm
Also, make sure you are using the correct gasket with the steel fire ring. 9.85 @ 145mph
5th Aug, 2008 at 05:01:39pm
Cheers guys. Il take it off and get the file out:) |
5th Aug, 2008 at 06:47:41pm
yes, please get the file out and not a second gasket...
