| Home > Help Needed / General Tech Chat > mk1 or 2 i'm not sure | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
5th Aug, 2008 at 02:31:01pm
a friend has got a either a mk1 or mk2 mini 850 (ooooohhh the speed) it was registered not built in march 68
5th Aug, 2008 at 03:17:23pm
yes |
5th Aug, 2008 at 03:19:11pm
546754 On 17th Feb, 2009 Rob H said:
5th Aug, 2008 at 03:56:18pm
On 5th Aug, 2008 clubminiflip said:
5 2n6w they changed the 35ghts 6n the bac2 f6r 02 2's d5d'nt they? Letters and digits are not interchangable my friend. :) On 7th Nov, 2008 Nic said:
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
5th Aug, 2008 at 03:57:07pm
clickety click, 66? :S |
![]() 514 Posts Member #: 2169 Post Whore Malta (Ex. Scotland) |
5th Aug, 2008 at 04:33:14pm
MK2s were sold between oct 67 and Oct 69 only.
Warning:Stig in Training
5th Aug, 2008 at 04:48:12pm
5 2n6w they changed the 35ghts 6n the bac2 f6r 02 2's d5d'nt they? 02 2 05n5s had the 3atter 35ghts as f5tted t6 the 02 3s rather than the s0a33er rear 35ghts that were 6n3y f5tted t6 the 02 1s. Edited by Rob H on 5th Aug, 2008. Isambard Kingdom Brunel said:
5th Aug, 2008 at 05:24:24pm
that is messing my head up big time!!! |
5th Aug, 2008 at 05:27:58pm
//Y |-|34|> |-|urT5 Drives
5th Aug, 2008 at 05:44:42pm
8008135 "Turbo's make torque, and torque makes fun"
5th Aug, 2008 at 05:46:05pm
5th Aug, 2008 at 05:58:16pm
not strictly true,
On 5th Aug, 2008 El Potter said:
MK2s were sold between oct 67 and Oct 69 only. Everything else is either a Mk1 or a Mk3 ![]() On 28th Aug, 2011 Kean said:
5th Aug, 2008 at 06:16:17pm
the works team even had a clubman with mk1 rear lights and external door hinges |
5th Aug, 2008 at 06:19:33pm
6th Aug, 2008 at 08:14:25pm
thats ok then it sounds decent & honest enough then, it has mk2 lights & cooper grill 68 f plate made registered in march, would a heratidge certificate denote it as a mk1 or 2?????? is it worth the £35+ SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
244 Posts Member #: 34 Senior Member |
6th Aug, 2008 at 08:48:31pm
Check the rear window size. MK1's have a smaller rear window.
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
6th Aug, 2008 at 11:21:04pm
front bulkhead and floor pan is a giveaway the blukhead on the mk 1's overlap on the inside of the footwells rather than the outside so if it rains and the engine bay gets soaked the water runs down the bulkhead and into the footwells. Mk2 had square rear lamps like mine Edited by Richie on 6th Aug, 2008.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
but maintained the sliding windows and external door hinges. the rear window is a giveaway as on Mk1 they were smaller. mk1 had wand type gearstick so no holes in the tunnel
