| Home > General Chat > Transverse to inline | |||||||
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
6th Aug, 2008 at 07:51:49pm
Can you change a transverse 'A' engine all variations to inline or visa versa. I sem to recall a twinni pickup used inline Morris Ital blocks and tranversed them http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
6th Aug, 2008 at 07:54:44pm
I think you can use the block but not the crank. |
6th Aug, 2008 at 08:43:17pm
Obviously crank is a total nono. I sold a Marina engine to a guy, and he fitted it in a Mini after much fettling with the front main cap. If you're fitting steel caps and line boring this is easy.
6th Aug, 2008 at 08:56:53pm
Its just that I have a fully sorted block that Im concidering to turn from transverse to inline
On 6th Aug, 2008 Vegard said:
Obviously crank is a total nono. I sold a Marina engine to a guy, and he fitted it in a Mini after much fettling with the front main cap. If you're fitting steel caps and line boring this is easy. The oil pickup will also need some modification, not sure what. Not worth it really as the proper blocks are dirt cheap. http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
6th Aug, 2008 at 09:09:02pm
No idea what's needed that way. On 13th Jul, 2012 Ben H said:
6th Aug, 2008 at 09:17:48pm
I,ve done it and still got the engine on the workshop floor.Pm me if you would like to discuss |
8th Aug, 2008 at 07:28:25pm
http://www.minimania.com/web/threadid/9360...8/msgthread.cfm
Edited by Vegard on 8th Aug, 2008. On 13th Jul, 2012 Ben H said:
8th Aug, 2008 at 11:22:44pm
i have heard of somone doing somthing abit like this a 4wd mini not sure if it ever was finished though, used a suzuki engine or somthing. but... if somone does create a subframe for a front engine A series rwd that would be awsome! Drives
