Home > General Chat > under crown cooling
Gavin Wakely
Member #: 793
Ive got an engine thats got undercrown cooling via carburettor jets (A Vmax Scart mod) positioned just above all three main caps in the block and angled up towards the undercrowns of the pistons but Ive noticed that many chaps on the site have a different set up which looks far superior. Does anyone have knowledge of the V Max and opinions on the please. Also doesn't this mod affect oil pressure
no
Isn't this what Nic has got?
Gavin Wakely
Member #: 793
Well carl thats brief*frown* no to knowing anything about it or no don't do it
On 6th Aug, 2008 fastcarl said:
no
No, to the last seven words of your post,lol
SumpNut
Member #: 28
I thought nic had some holes simply drilled in his con rods around the big end which shoot oil upto the piston?
Nah, main bearing housing..
GaryOS
Member #: 2810
Formally spanner181187
Dublin, Ireland
If you use the Ford jets (part number 1053936) then oil pressure doesn't suffer. They have a pressure valve (spring and ball) which stays closed below a certain pressure. I don't know what pressure though!
On 30th Apr, 2010 Rod S said:
Gary's description is best
I believe they stay shut until 30psi..stand to be corrected though!
i don't believe we need under crown colling any way IMO*wink*
Sam
Member #: 1686
Oxford
indeed. the ammount of oil being flung up by those gears and the crank negates the reasoning for the undercrown jets unless you have a windage tray.
OMG Robert that's a big one
What about #1 piston? I don't see much oil spray from the gears under that cylinder?
IMO (LOL) it is a worthwhile mod!
Sam
Member #: 1686
Oxford
thats very true, dident think about that.
What point would you need them though?
has anyone got pictures of theses jets and how are they fed? i dont understand how they work really could somone explain for me please :)
cheers paul
Sam
Member #: 1686
Oxford
taken from phills site.
http://www.turbo-mini.com/mediac/400_0/med...ndercrown~1.JPG
you drill the block aiming towards the oil gallery
GaryOS
Member #: 2810
Dublin, Ireland
Theres a few pics of them in my build thread too. Although with the way I done it, it will probably confuse the matter more than clarify it *tongue*
i use the ford jets in my engine. I'm not sure if thaw have helped my engine. But in the last 6 years of running up to 20psi i've never had a problem. And if they don't do anything then nothing lost. Con anyone think of a disadvantage of running them?
They're not essential, but, anything that aids reliability must be worthwhile, plus it's a cheap mod anyway.
A lot of production cars have them fitted, so manufacturers must think there's a benefit/need to fit them.
Edited by Turbo Phil on 7th Aug, 2008.
Vizard also covers them in the big yellow book...
the only disadvantage i can think of Jim is your pulling oil away from the rest of the engine, but i'm sure people on here say the pumps are more then up to the job. Just don't use a Standard oil pump like i use lol.
