| Home > Help Needed / General Tech Chat > Megajolt Installation with rev counter. | |||||||
329 Posts Member #: 3193 Senior Member Torbay, Devon |
7th Aug, 2008 at 08:38:08am
7th Aug, 2008 at 10:44:59am
Any rev counter should be ok, try http://www.minispares.com/SearchResults.as...mple&ty=fi&rt=1 and http://www.minispares.com/SearchResults.as...mple&ty=fi&rt=1 for the bezel |
7th Aug, 2008 at 11:06:19am
i think no 11 on the megjolt is the one for the rev counter
Edited by philc on 7th Aug, 2008. |
7th Aug, 2008 at 11:27:59am
You can use the Megajolt output on most aftermarket rev counters.
In the 13's at last!.. Just |
![]() 902 Posts Member #: 111 Post Whore Loughborough |
7th Aug, 2008 at 06:17:34pm
Mine works fine striaght from the megajolts. no problems. |
![]() 189 Posts Member #: 1774 Advanced Member Sydney AUS |
8th Aug, 2008 at 02:54:25am
Mine 'was' working fine from the pin for Rev counter (MJ V4) but then got very bouncy, etc)
1132cc Turbo ~120 bananas ATW - Fun Fun Fun
8th Aug, 2008 at 09:49:58am
Got a small TIM rev counter working using the diode circuit on megajolt site. -MINI CLUBMAN 1380 TURBO- |
8th Aug, 2008 at 10:49:20am
So just +ve to the pip and -ve to ground? |
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
8th Aug, 2008 at 04:15:30pm
I had to plumb mine into the PIP signal to stop the bounciness.
8th Aug, 2008 at 04:53:08pm
Will the standard mini counter work from the MJ PIP?
9th Aug, 2008 at 08:45:33am
On 8th Aug, 2008 theoneeyedlizard said:
Will the standard mini counter work from the MJ PIP? Don't know but it definitely works if you connect it to the tach output on the EDIS module. I tried both the MJ tach output & the diode circuit but neither of them worked with the Rover tacho. Edited by Rob H on 9th Aug, 2008. Isambard Kingdom Brunel said:
9th Aug, 2008 at 08:54:39am
This is what I thought.
9th Aug, 2008 at 04:38:15pm
On 9th Aug, 2008 theoneeyedlizard said:
Does anyone know what pin is the tach output on the EDIS? On 7th Aug, 2008 philc said:
i think no 11 on the megjolt is the one for the rev counter this may be useful http://www.putfile.com/pic/5150366 Isambard Kingdom Brunel said:
9th Aug, 2008 at 05:18:01pm
Or you can use teh tach out on teh MJ itself, although it can become bouncy |
9th Aug, 2008 at 08:43:06pm
I use the pin 11 off the edis unit, I did try the Tacho output from the mj but the gauge didnt work on over run! |
11th Aug, 2008 at 03:27:07am
You just splice into the pip on and connect the signal wire to that... tacho works g-reat! (Mine is aftermarket tacho) not sure about the rest, soz.
11th Aug, 2008 at 08:05:21am
i have a rover tacho and race tech both work fine through the mj |
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
19th Oct, 2008 at 09:49:30pm
Sorry to drag up an old post.
6 Posts Member #: 3929 Junior Member |
7th Dec, 2008 at 07:39:55pm
could you fit the white and black wire from the coil to the rec counter gauge of the edis in order to got rpm on original 3 clocks ? |
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
7th Dec, 2008 at 08:33:23pm
My Metro tacho didn't work properly from the MJ output so I tee'd into the PIP wire and it's OK now Geoff |
