| Home > Wanted > Dump Valve and 3 way bleed valve kit **please delete i have been sortid out thanks** | |||||||
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
7th Aug, 2008 at 08:06:15pm
As per title folks still need some bits and bobs to progress me build. Edited by Richie on 13th Aug, 2008.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
150 Posts Member #: 1591 Advanced Member Prudhoe, Newcastle |
7th Aug, 2008 at 08:45:37pm
your lucky day. I have a dump valve spare. Ive just advertised my turbo on ebay inc the bleed valve, but i could edit it if you want that ?
7th Aug, 2008 at 08:49:29pm
seen here but comes with silicon pipe instead of the clear stuff. The clear stuff goes soft and melts after a while. Silicon pipe wasnt cheap but its worth it.
Edited by JordieNE on 7th Aug, 2008. |
7th Aug, 2008 at 09:51:20pm
thats a good DV, same as i've got and had it on 3 or 4 engines. |
8th Aug, 2008 at 12:00:00am
Jordie how much you want for it fella ?
8th Aug, 2008 at 06:59:03am
swap for a 12g940 standard 1275 cylinder head lol.
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
8th Aug, 2008 at 07:57:16am
£20 is a bargain!
8th Aug, 2008 at 10:54:08am
Cool, did you run BV inside your car ? and if so have you still got it ? I will take the DV off you for sure, i got no 1275 heads left unfortunately, however if you get one, i have a full race longman which i could give to Steve as reference if you wanted a head cut again :) I know a guy who has tonnes of gear may have one i will make a call for you now
![]() 53 Posts Member #: 1675 Advanced Member |
8th Aug, 2008 at 11:40:15am
the bleed valve is an engine bay one.
8th Aug, 2008 at 12:04:43pm
As tom said, i have the bleed valve that goes in the engine bay. Its a 3 leg avonbar one.
8th Aug, 2008 at 12:20:57pm
Cheers Jordie, and Yes Tom i am aiming to get the car running (not road legal but running
8th Aug, 2008 at 12:42:26pm
Right ok richie. just let me know. Ive got an unleaded 1275cc head in the garage, but needs a push rod sleeving and i dont think ive got time to send it away for it to be done. |
8th Aug, 2008 at 12:50:27pm
no sweat as soon as he gets back to me i will either pop a message on here or text tom.
8th Aug, 2008 at 01:03:12pm
i might follow you down buddy. when you thinking of going ? |
8th Aug, 2008 at 04:29:54pm
as soon as its done :) going down with Steve and Dean.
8th Aug, 2008 at 05:32:11pm
waiting at this end when your ready richi, will be a good day out
12th Aug, 2008 at 12:41:09pm
Jordie, can you give the DV to Tom and i will give him the Twenty ? I was going to call around at neils tonight if he is in, do you still need a stock 1275 head ?
12th Aug, 2008 at 12:50:20pm
Richie. Ill fetch the DV over to tuk's tonight or give it to him depending on what im doing tonight.
12th Aug, 2008 at 01:26:52pm
Rock on !!! i have valve pastes and stick if u need em
12th Aug, 2008 at 04:42:57pm
could do with some now lol |
12th Aug, 2008 at 06:51:25pm
no sweat give the two pots (fine and corse) and the stick to Tom.
12th Aug, 2008 at 11:53:57pm
Finished with the stick and that richie. Will get it back to you through tom in the next few days. |
13th Aug, 2008 at 09:14:43am
no sweat fella, think i may have a fiddle and see which way to do the boost pipes today. i take it the small pipe on the DV just goes onto the nipple behind the carb (i used the one that the vacume pipe would have gone on if using a dizzy ?
13th Aug, 2008 at 12:06:25pm
Yeah thats right richie. I used that the servo take off with a modified adaptor on my inlet manifold to run mine. Jordie |
) then trailer it down to Bogg bros for tune up.
