| Home > Help Needed / General Tech Chat > K100 Clearence | |||||||
69 Posts Member #: 1670 Advanced Member |
9th Aug, 2008 at 10:57:32am
In a round nose mini, does the bonnet supports need to be cut/removed or replaced ???
1425 Posts Member #: 690 Post Whore Norfolk |
9th Aug, 2008 at 03:22:41pm
You'll be lucky to get away without removing a bit of the "X" brace. Both 8v twinks I've done so far have been clubbies which fit without bonnet mods If Carling made Mini engines
9th Aug, 2008 at 05:54:15pm
I had to cut mine out. The centre of the cross brace touches the front middle section of the cam cover. I just cut mine as close as I could to the corners. Edited by matty on 9th Aug, 2008. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Aug, 2008 at 07:27:25pm
I have taken extra measures to try and get away without removing the cross brace, but I am not sure if it will be enough, will have to wait to get the engine in the car On 26th Oct, 2004 TurboDave16v said:
9th Aug, 2008 at 07:43:23pm
Thanks guys, i knew it would be hard to get away without removing some of the brace, glad to hear i only need to cut "some" of it away. Thanks again.
9th Aug, 2008 at 08:00:05pm
I know Miniminor63 had to remove the X alltogether. On 13th Jul, 2012 Ben H said:
9th Aug, 2008 at 08:04:02pm
On 9th Aug, 2008 spacecowboy said:
Thanks guys, i knew it would be hard to get away without removing some of the brace, glad to hear i only need to cut "some" of it away. Thanks again. matty - any chance of a picture of the underside of the bonnet just so i can have a look. Tom Just imagine the bonnet without the cross brace, and only the corners with the hinge brackets left on
123 Posts Member #: 1234 Advanced Member Chester |
10th Aug, 2008 at 02:12:31pm
I cut all mine out, but the bonnet is bendy as hell without it. Should be able to get away with cutting less out, but I couldn't be arsed messing around with it.... just wanted to get it going and was planning to put a carbon/glass fibre one on. |
10th Aug, 2008 at 10:22:33pm
As I discovered today the head end plate also just slightly rubs on the bonnet above the inlet pulley. A slight tilt on the bonnet would sort this though. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
