Home > General Chat > the hog is alive and kicking again
turbo hogster
Member #: 178
stowmaket suffolk
well after having to do a engine change on the side of the road whilst the nes pig sty is being built, she is alive and kicking again.
graced with some new 14cc +20 accrilites, i managed to dodge the showers and get her fitted.
took her for a test drive and everything seems well.
had a bit of a due as i pulled in to the petrol station to check tyre pressures the kwick shift screws decided to come undone and couldt get any gears let alone reverse, but managed to in the end but the only gear i could get was first or 4th so trundled the mile back home in 1st.
so jobs to do is try and get exhaust on a bit better underneath, sort out gear stick and try and get a bit more clutch, i fitted a new ralley plate but it bites at the bottom and is a bit judery.
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Good to hear
El Potter
Member #: 2169
Malta (Ex. Scotland)
Well done!!
Warning:Stig in Training
Pleased for you mate, well done for all that.
Sam
Member #: 1686
Oxford
nicely nicely, turning up the boost now with the new pistons?
OMG Robert that's a big one
Good Un Hoggy
T3Tone
Member #: 252
Sunny suffolk
Well done that man.
-MINI CLUBMAN 1380 TURBO-
turbo hogster
Member #: 178
stowmaket suffolk
well been out today, sorted gear stick , exhaust and the clutch
every thing seems ok clutch seems to judder a bit with the new plate.
tried to get 2 new tyres down my local shop, he has been very good in the past but could only get continental at £58 each plus vat, mind you that includes fiiting ect.
but will see what i can get at mttp
Sam
Member #: 1686
Oxford
continentals arnt bad. they certainly take some abuse.
you have to be carefull with them in the with them in the wet.
unless i swing wide on tight round abouts in the wet the back end can come out if im a little bit entusiastic.
