Home > Help Needed / General Tech Chat > K1200 temp control....
nbooth660
Member #: 1234
Running in my Twinky engine and the water temperature fluctuates between 80-90 degC. Got an 82 thermostat in with a small hole drilled in it to get the water to flow out of the head and into the thermostat housing.
Any thoughts why it's not stable?
Nick.
miniboo
Member #: 2253
Las Vegas, Brit in the States
if you are using that one hole as the bypass i would drill a few more.
nbooth660
Member #: 1234
Yes that's all I'm using as a bypass. I had a bigger hole in the last one I had in and it ran at 70 deg when moving and 85 deg when still. I thought from that I was getting too much water bypassing the thermostat as it never got up to temp when moving????
Im running an external bypass thermostat off a *cough* Lada *cough*, works a treat! *wink*
Matty I remember your comment when i mentioned the thought of fitting a Lada part to your car *laughing*
Haha I can't remember exactly what I said but I can imagine the lines it was along! *laughing*
nbooth660
Member #: 1234
Matty,
Does that run a bypass or does all the water flow through the thermostat?
I've got a home made remote housing with no bypass so I drilled a hole in the thermostat to get the water to flow a little.
Nick.
Its got 1 inlet 2 outlets and basically a shuttle valve. When it cold it goes one way when its hot it goes the other!
When its cold the water still circulates around the engine but bypasses the rad completely, when open it goes via the rad.
Im running an electric pump and didn't want to restrict the flow at all when the thermostat was closed, this way it stays constant. *wink*
Edited by matty on 11th Aug, 2008.
