| Home > Help Needed / General Tech Chat > Pre-verto question | |||||||
152 Posts Member #: 2190 Advanced Member South Carolina, USA |
10th Aug, 2008 at 07:19:31pm
I am trying to disassemble a pre-verto clutch…there are 3 jack bolts that go through the diaphragm and into the flywheel, so that you can slowly release the spring pressure. Does anyone know what thread size that is? It is not 3/8â€-16…I am thinking it is 3/8â€-24 but just want to confirm because I will have to order that, nobody carries fine threaded rod locally…Thanks |
10th Aug, 2008 at 07:49:28pm
Whoaaa.
11th Aug, 2008 at 02:15:50am
I apologize in advance about posting copyrighted material but I did not know any other way to communicate what I am talking about. I will take it down if it is a problem….
11th Aug, 2008 at 06:55:06pm
that looks like a puller to me =/ Drives
11th Aug, 2008 at 06:59:56pm
Thats a picture of the method to dissassemble the ye olde spring type clutch.
Edited by Sprocket on 11th Aug, 2008. On 26th Oct, 2004 TurboDave16v said:
11th Aug, 2008 at 07:00:31pm
That picture does not make any sense at all.....
11th Aug, 2008 at 07:02:17pm
The picture is right, just not for the clutches that are available any more, they went out of fashion with the kipper tie On 26th Oct, 2004 TurboDave16v said:
11th Aug, 2008 at 07:04:42pm
On 11th Aug, 2008 Sprocket said:
Thats a picture of the method to dissassemble the ye olde spring type clutch. I think you're right.... I was only 17 years old when I dismantled a coil spring one - and that was a long, long time ago...... Do any still exist ??? Schrödinger's cat - so which one am I ??? |
11th Aug, 2008 at 07:11:01pm
On 11th Aug, 2008 retired said:
11th Aug, 2008 at 08:09:38pm
Right, here is a pic of a normal PRE-verto cover, first from the inside with a diaphragm spring.
11th Aug, 2008 at 08:56:47pm
Just also remembered, if it really is that old to be the coil spring type, the primary gear ran on white metal bearings (not bronze bushes) so there was an extra drilling in the crank to feed those bearings with pressurised oil, and an extra oil seal in the back of the flywheel to keep that oil in, which didn't work, which is why (many, many years ago), I ended up dismantling one.... and throwing the whole thing away !!!
11th Aug, 2008 at 11:31:53pm
My saga continues…it seems I have every potential odd ball part possible….apparently you guys are telling me I have the last existing spring type clutch. I am assuming that is a bad thing. My original plan was to open it up replace the clutch disc and ring gear and move on…but now you got me wondering what I should do with it. Please let me know…would you chuck this one and buy a new one? If so which one?
… an extra oil seal in the back of the flywheel to keep that oil in… Is this the seal you are referring to? I am not aware of any extra drilling in the crank…but then again I do not know what I am looking at... Just to prove I have the old school spring type clutch…not pretty but I thought it would work…
11th Aug, 2008 at 11:35:06pm
Do any still exist ??? Exactly!!!! Well fook me they do
11th Aug, 2008 at 11:35:49pm
Id bin it and get a new one Edited by Sprocket on 11th Aug, 2008. On 26th Oct, 2004 TurboDave16v said:
11th Aug, 2008 at 11:48:50pm
Apparently I am here to prove that rocking horses do shit….in the form of a rusty spring clutch.
11th Aug, 2008 at 11:54:03pm
Do you know if I can get away with reusing the pressure plate and flywheel and just replacing the diaphragm with one of these...
Edited by Mikes1098 on 12th Aug, 2008. |
12th Aug, 2008 at 08:14:01am
On 11th Aug, 2008 Mikes1098 said:
Is this the seal you are referring to? I am not aware of any extra drilling in the crank…but then again I do not know what I am looking at... No, that pink one is the normal primary gear oil seal which every possible version has. The primary gear is the bit that you can only see the clutch splines on in your photo (the gear bit being behind the casing). Nowadays that bit runs on the crank tail on two self lubricating bronze bushes. On the VERY early ones, they used to be whitemetal bearings and there was a small oil feed to the inside of the gear (which you wouldn't see with the gear in place) and in the BACK of the flywheel was another lip seal to keep the oil inside the gear, not onto the clutch.... The whitemetal bearings were discontinued very quickly but I can't remeber if it was at the same time as the coil spring clutch was discontinued. I think the whitemetal bearings were abondoned first. Look in the back of the flywheel, up the bore, near where the taper starts, and see if there is a lip seal there. Also see if there is much side to side play between the primary gear and the crank tail, the whitemetal ones wore out very quickly. On 11th Aug, 2008 Mikes1098 said:
Do you know if I can get away with reusing the pressure plate and flywheel and just replacing the diaphragm with one of these... From dim and distant memory, your flywheel will have six recesses in it for the coil springs to locate in. Flywheels designed for the diaphragm spring have a single large circular groove for the diaphragm spring to sit in, I don't think that groove will be there on the coil spring version. I would try tracking down a second hand "normal" assembly. Obviously in the UK that would be dead easy, I realise it might not be so easy for you. However, if you are unlucky enough to also have the VERY early whitemetal bearing primary gear, you are truely stuck - only the matching flywheel will have the extra lip seal. Rod. Schrödinger's cat - so which one am I ??? |
12th Aug, 2008 at 08:29:48am
BTW, back to your original question, the "jacking" studs use the flywheel puller threaded holes (so I'm 99% certain it's 3/8" UNF (24tpi)).
12th Aug, 2008 at 11:31:25pm
Rod you are helping me tremendously. I only have a few more questions and I wanted to post pictures for reference just in case someone else gets lucky too…
13th Aug, 2008 at 09:12:30am
You don't have a problem with that primary gear, it is the bronze bushed one. The little holes are (I think) to let any oil out that might have run along from the No3 main bearing so that no significant amount gets to the end of the primary gear where the clutch is. Anyway, they are perfectly standard on the bronze bushed ones.
13th Aug, 2008 at 01:20:07pm
Is there any advantages/disadvantages to the two different types of 'later' pre-verto flywheel (ie two piece or one piece)? |
13th Aug, 2008 at 03:54:39pm
i'd just buy a new ultra light flywheel, steel back plate, grey diaphram and ap bonded rally plate and be done with.
13th Aug, 2008 at 10:50:16pm
I think I may have to just buy new... I have not had too much luck with anyone offering up an extra one in the states. They are probably on every corner over there...My only hope would be if someone would be willing to stick one in the post for me |
13th Aug, 2008 at 11:27:16pm
You could refurbish and try the coil spring flywheel/clutch first before spending lots on new parts....
14th Aug, 2008 at 12:06:15am
On 13th Aug, 2008 Rod S said:
You could refurbish and try the coil spring flywheel/clutch first before spending lots on new parts.... That is a great plan! I can always replace it later if I want more. I got distracted with idea that this clutch is bad. I had to scroll all the way to the top to remind myself what my original question was. The clutch does appear to be salvageable even though it is ugly in the pictures, however I did want to replace the disc since this way has been sitting idle since 1970. I am assuming the pre-verto disc will be the same…I will find out when I open it up. On 13th Aug, 2008 Rod S said:
…Of course every bit of your engine may be a different age anyway - in the photo, the condition of the engine looks a lot better than the flywheel !!! THANKS!!! I am slowing breathing life back into it. It was no beauty when I started.... |
