Home > Wanted > harness mounting bushes
steve w
Member #: 1917
AKA chargedzetec
Im after 4 of the bushes that are used when mounting harnesses.
the ones that allow you to bolt the harnesses in, as per the usual mounting points, but still allow them to swivel.
cheers
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Are you on about the eye bolts?
On 19th Jan, 2010 wil_h said:
steve w
Member #: 1917
AKA chargedzetec
no, you can get stepped bushes that allow you to bolt the harnesses in.
it looks like a tophat
do you mean these:
http://www.merlinmotorsport.co.uk/p3155/SP...oduct_info.html
If so I've got a load.
I think he is on about the things that are basically a spacer. But they then step down so they fit through the hole in the harness mounting point.
The bolt then tightens up against the spacer and lets the harness mount swivel rather than directly clamping the harness mount.
I'll see if i can find something on the net to show what im talking about.
EDIT:
Like this:
the step downs aren't usually as long as that though.
Edited by James_H on 17th May, 2009.
steve w
Member #: 1917
AKA chargedzetec
james , exactly like that!
ended up getting them made at work
cheers anyways chaps
