Home > Wanted > carb restrictor plate
boz-reb-2303
Member #: 2301
Blackpool , Lancashire
mg turbo carb restrictor plate apparently it sits between carb and plenum. ours is missing if any one has a spare or a pic of one cheers
http://s256.photobucket.com/albums/hh167/boz-reb-2303/
http://s609.photobucket.com/albums/tt176/boz-reb/
1971 turbo mini van
1978 clubman estate
1971 clubman
There isn't such a thing as standard. The restrictor is a brass tube in the plenum.
There isn't a restrictor plate as such, the restrictor is built into the plenum and is a cylindrical brass insert with two slots in it. If you can post a pic of your plenum then we can confirm it is still there for you.
boz-reb-2303
Member #: 2301
thanks for that. mine dos ant seem to have one. do you think this will make any difference to my front mounted supercharger.
I'm so close to getting it working its pi**ing me off. LOL
HAS ANEY BODY GOT ONE.
1971 turbo mini van
1978 clubman estate
1971 clubman
boz-reb-2303
Member #: 2301
or a plenun
1971 turbo mini van
1978 clubman estate
1971 clubman
The restrictor is required to make the carb sensitive to boost, without it your fueling will be permanently on another planet.
