| Home > Help Needed / General Tech Chat > OT R Reg Ford Fiesta 1.25 Zetec Clutch Problem | |||||||
14th Aug, 2008 at 07:31:27pm
Fellas, just replaced the Slave Cylinder in my Mothers Fezza Clutch, the problem is were having trouble re bleeding it. The clutch bleeds but after 2 pumps of the clutch you loose all pressure, if you leave it for a minute or so the clutch comes back and after 2 pumps goes away again???
14th Aug, 2008 at 10:17:20pm
most probably air. give it shit when bleeding it or use an ezebleed or similar.
15th Aug, 2008 at 07:53:43am
Yes were going to use an easybleed. Thanks for the advise mate!
On 14th Aug, 2008 James_H said:
most probably air. give it shit when bleeding it or use an ezebleed or similar. you might find that even with a power bleeder you still need to pump the pedal to release all the air becuase some can be really stubborn! ooo and make sure that when your bleeding it that the pedal is held down when you lock off the nipple otherwise it could be sucking air back in. sorry if that seems abit pedantic. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
