Home > Help Needed / General Tech Chat > Engine position
Kean
Member #: 341
aka T2clubby
South Staffs
Hey everybod... has anyone redrilled their engine mount holes on the subframe... if so how far forward can you go without running out of space and/or causing driveshaft trouble??
I have my engine mounted in the std place on the std subframe. But I'm thinking of moving it back closer to the bulk head.....
also you need to consider, the further foward you mount your engine, the more understeer you'll get, although you will get off the line better.
space is usually tighter at the front than the back, intercooler etc *smiley*
Nick
Member #: 154
Midlands
he's got a fair bit of room at the front though as its a clubby estate he's turboing. but we're going to use the mirage kit so just wanted to get a bit of extra clearance.
Got a 2wd cossie IC to go in, looks like it'll be a perfect size and fit, just gotta move the numberplate.
Kean
Member #: 341
aka T2clubby
South Staffs
Just take the words right out my mouth why dont ya bud....... your only jealous of my ample fitting space :p
Carl
Member #: 95
liverpool-on-sea
id say leave it were it is and use the space for i/c etc
Kean
Member #: 341
aka T2clubby
South Staffs
I have plenty of room at the front cos its a clubman and im using a cossie intercooler that fits perfect.....
Just thought it would be nice to have a little space at the rear for the t2
if there isnt an issue with clearance at the back why bother?
work for no reason really *smiley*
evolotion
Member #: 83
Glasgow, Scotland
if your realy bothered you could extend the top engine mount so it tilts the engine forward a touch, or use an automatic mount.
Denis O'Brien.
