Home > Wanted > mega urgent- pre A+ transfer casing and more....
need a pre a plus transfer case
and/or
J/K s/c idler gear (the middle one)
bothe needed really
just on the off chance somebody has a fcuked set bar the one i need
cheers
or A+ s/c drops....
miniboo
Member #: 2253
Las Vegas, Brit in the States
I have a Pre A+ transfer case, not sure how much postage will be though. it also has a bit missing where the start fits but it doent affect anything. want a pic?
your in vegas?
i could prob get carl to make one from Ti for less than the postage on that bad boy!
thanks for the offer il see if there is any left in the uk....lol
why 'pre A+'? the only difference is the £7 bearing iirc?
I have a spare if you're interested but you can convert an A+ to take the smaller bearing with this
http://www.minispares.com/Product.aspx?pid=38305
Star Mag
Member #: 375
Leicestershire
I had one of these conversion bearings and it dropped into my gearbox! Bad Times I dont know if anybody else has had a similar problem?
miniboo
Member #: 2253
I doubt postage will be that much tbh. it isnt that heavy. will probs only be $30ish. if i can get it into a flat rate mailbox it will be even cheaper
I remember you saying in an earlier thread....
However, if it's only the transfer casing that needs the sleeved bearing (and not the gearbox casing as well) it shouldn't be able to fall out of the transfer casing as it's a blind hole !!!
I have the right transfer housing anyway if it's wanted, the sleeved bearing was just a suggestion to save cost/time.
sorted now cheers guys!
