| Home > Help Needed / General Tech Chat > can anyone help which petrol tank do i need for a turbo | |||||||
21 Posts Member #: 3508 Member sheerness, kent |
16th Aug, 2008 at 03:42:20pm
i no i need one with a return but not a 100%
16th Aug, 2008 at 04:09:35pm
Only the injection tanks had a return, most people weld / braze a return on to there tank. Isambard Kingdom Brunel said:
16th Aug, 2008 at 04:47:25pm
simplist thing is to get an MPI tank,
![]() 69 Posts Member #: 1163 Advanced Member Malvern, Worcestershire |
16th Aug, 2008 at 07:43:49pm
I run an MPI tank. Simplest way to go. Got mine off ebay for £8 so not gonna break the bank. |
16th Aug, 2008 at 08:20:39pm
if the mpi tank has a pump in it does that mean i dont need to buy a petrol pump |
16th Aug, 2008 at 08:36:29pm
16th Aug, 2008 at 09:20:39pm
cheers matey
16th Aug, 2008 at 10:26:35pm
Just make sure you get an MPi tank, the SPi tanks is only 1.5 bar. Plus use an intertia switch. On 7th Nov, 2008 Nic said:
17th Aug, 2008 at 04:37:45am
3 Posts Member #: 3372 Junior Member |
20th Aug, 2008 at 10:08:30pm
whats the best size pipe outlets to have on a normal tank for a turbo,if you get me. mine had a problem running but knocked off the inline tank filter and think i have cured the problem |
21st Aug, 2008 at 10:27:11am
They need to be 8mm |
21st Aug, 2008 at 10:39:15am
8mm ID on feed and return?
21st Aug, 2008 at 10:53:38am
Yep on feed and return, you can run copper through the car, i wouldnt use anything else though. |
21st Aug, 2008 at 01:03:23pm
On 21st Aug, 2008 gavin@minispares.com said:
Yep on feed and return, you can run copper through the car, i wouldnt use anything else though. If you are going to do that run your lines inside a steel tube to prevent any damage being inflicted on them. I run a 10mm feed and return, what ever pump you fit the feed line from the tank has gotto be of a greater ID than the entry fitting on the pump otherwise YOU WILL have fuel feed issues. Own the day
21st Aug, 2008 at 01:10:48pm
On 16th Aug, 2008 Jay#2 said:
Just make sure you get an MPi tank, the SPi tanks is only 1.5 bar. Plus use an intertia switch. you only need to supply fuel at 5psi of pressure at idle and the pump must be able to match the boost pressure. so if your running a standard turbo at 3-5psi of boost the fuel pump only need be able to make 10psi max so a 1.5 bar pump (21psi) is more than sufficient. Running a fuel pressure gauge is a good way of checking the condition of your fuel system. Own the day
21st Aug, 2008 at 01:14:46pm
On 16th Aug, 2008 mini13 said:
simplist thing is to get an MPI tank, this has a high pressure pump built in and has the return, meaning you just need to run a pair of suitsbly sized pipes to the front, i have jsut fitted twin tanks, i'll pop up a pic in a bit. I have a full set of pipes and several tanks taking up space up for grabs if you want them you will have to collect. Own the day
21st Aug, 2008 at 02:22:54pm
On 21st Aug, 2008 Mr Joshua said:
I run a 10mm feed and return, what ever pump you fit the feed line from the tank has gotto be of a greater ID than the entry fitting on the pump otherwise YOU WILL have fuel feed issues. are you sure? i have a standard van tank with the standard tiny fuel pickup with the filter removed (say 4mm?). the return is a similar size and is the steel pipe that used to be a fuel overflow pipe from the carb on a metro. the main line front to back are about 8 or 9mm id and i use a metro turbo pump and thats about 12+mm one end. does that mean my system doesn't work? |
23rd Aug, 2008 at 10:13:52pm
On 17th Aug, 2008 Turbo Tel said:
You could always use a standard tank with a T piece for the return....I do, Well its actually a fuel filter with 2 inlets. one comes from the tank, one from the regulator return. the outlet feeds the fuel pump which sends pressurised fuel to the regulator. There are a few others doing the same thing, it seems to work. Terry Sorry to dig this up again but i've been thinking about this as it seems a great way to get around having to mod tanks/get an injection tank. I found this little chappy: http://www.demon-tweeks.co.uk/products/Pro...pcode=FSEMYP001 Up to the job of what you describe? I cant seem to find 2 inlet to one outlet filters anywhere if you can? As id prefer this, just so i can see the fuel's moving about! Edited by richminiturbo. on 23rd Aug, 2008. |
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
23rd Aug, 2008 at 11:13:50pm
mini13 did you ever get pics of how you have plumbed in your twin tanks and returns? |
23rd Aug, 2008 at 11:19:19pm
Yes it would do the job, but i decided to use a fuel filter as it gives a little resoviour of fuel which in my mind may help with any airation etc..
On 23rd Aug, 2008 richminiturbo. said:
Sorry to dig this up again but i've been thinking about this as it seems a great way to get around having to mod tanks/get an injection tank. I found this little chappy: http://www.demon-tweeks.co.uk/products/Pro...pcode=FSEMYP001 Up to the job of what you describe? I cant seem to find 2 inlet to one outlet filters anywhere if you can? As id prefer this, just so i can see the fuel's moving about! Yes it would do the job, I think that what others have used but i decided to use an approx 1-1/2 inch diameter x 3 inch fuel filter as it gives a little resevour of fuel which in my mind may help with any airation etc. Terry website:- http://www.terryhunt.co.uk
