| Home > Help Needed / General Tech Chat > Supercharger pulley dimension. | |||||||
976 Posts Member #: 3228 Post Whore North of the Netherlands |
16th Aug, 2008 at 07:00:56pm
Ok here we go again.
Dazed and Confused.... |
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
17th Aug, 2008 at 05:07:33pm
http://www.amazon.co.uk/AUTOMOTIVE-SUPERCH...18988208&sr=8-1
Bugger off, I'm getting there. |
17th Aug, 2008 at 07:00:04pm
Thanks very much for the reply Hedgemonkey.
17th Aug, 2008 at 08:24:08pm
Interesting. I'd be interested in seeing how you bracket it up and compare that to mine (in bits again). I'm assuming you're rigging it OO and removing a bit of the bonnet catch panel. You need to take out about 8mm IIRC. Bugger off, I'm getting there. |
17th Aug, 2008 at 10:03:01pm
Dont worry about blowing the intake charge out the exhaust. That theory is over-exaggerated.
18th Aug, 2008 at 07:12:26pm
Ok, perfect, so a pulley sized 75mm will give about 10+ psi.
) in a mini that is used for weekend drives.
