Home > Technical Chat > A/F ratio
bigmini998
Member #: 2830
Costa del Northern Ireland :)
ok going to have a go at setting this mini up tonight wot a/f ratio should I be aiming for ive heard 13 is ideal but a mini has to run richer so 12- 12.5??? *oh well*
cheers guys
That mini is determined to Kill me!!!!
13 is a tad lean
matnrach
Member #: 1074
Northamptonshire
I am running a downpipe lambda of 0.86 with 0.6bar boost at the moment with TBI (12.6 afr).
I would guess at 13:1 the leaner cylinders would be too lean hence an average tailpipe reading of 12.3-12.7 would be ideal
Turbo Tel
Member #: 588
Delaware, USA
The numbers above look great to me. 13 is the theoretical best power point but the tendancy is to give a turbo a liitle more fuel to help cool the cylinders. Some peeps run even richer but there is a suspicion out there that overfuelling can make any detonation more destructive...plus it will be a bit lower on power.
BTW these numbers are under accelleration, for cruise and idle you want nearer 14-14.7 and dont worry if you see 16 or so on the ovverrun
Edited by Turbo Tel on 19th Aug, 2008.
pristic
Member #: 1774
Sydney AUS
Dont forget also that the lambda sensors send spikes too... so 'too rich' can show up wrong and too lean also show up wrong, its good to get the overall A/F true though... mine was at one stage hitting 16+ on full boost... but richened up now.
1132cc Turbo ~120 bananas ATW - Fun Fun Fun
matnrach
Member #: 1074
Northamptonshire
Not sure what you mean by 'spikes'.
When the sensor is in such a position so as it will not see exhaust leaks or be too close to the end of the pipe then when calibrated correctly will give very good results.
'Spikes' can occur on rapid tranisents but these are very real.
If you map too close to lambda 1.0 then a rapid transient will push the average lambda well over 1.0 causing some hesitations.
With correct transient fuelling multipliers these can be minimised so that the response can be very good indeed.
It takes some experimenting but the results are worth it.
bigmini998
Member #: 2830
forgot to read in distructions *oh well*
couldnt get the wideband up and running as my lap top doesnt have a serial port so off to pc world for a 232-usb connector another wasted day............. *Rofl!*
I would suggest getting a PCMIA to 232 card, i got one for half the price i paid for a usb cable and it seems much more reliable.
http://cgi.ebay.co.uk/PCMCIA-RS232-RS-232-...1742.m153.l1262
bigmini998
Member #: 2830
aah i see cheers for that :) im not a very computer person for a mechatronic engineer ha ha *happy*
pristic
Member #: 1774
Sydney AUS
Thats actually what I meant, depending where its reading from, etc. Mine was reading fine, but hitting full throttle or completely backing off things would go haywire.
There was a leak between dump pipe and the exhaust, which made the lambda a little off.
Also there was not enough flow in idle for it to read right, it was reading 19+ on the A/F on idle, which was completely wrong, giving it another 200rpm by pressing the pedal and it all settled down and sat on 12.7 A/F
The dyno op also said there are a few factors which can throw them out.
Dont get me wrong, anything I change, I got and check the A/F with the lambda, just pointing out that they can give some odd results sometimes if not setup 100% right.
I know cars like the GTR's have the o2 sensor in the turbo itself for the computer to adjust to... and we usually stick our in the tailpipe... so any leak at all comes up as a wrong (or slightly off reading)
Pete
Peter
