| Home > Help Needed / General Tech Chat > Ouch More f'in money! | |||||||
166 Posts Member #: 221 Advanced Member |
15th Aug, 2004 at 06:58:12pm
Just got my clutch fixed and car tuned. Is going, or so I thought..........when engaging fourth gear as soon as the clutch is let back out it pops back out of gear. Basically it wont stay in fourth gear. |
15th Aug, 2004 at 07:23:17pm
gearbox...
AlexF |
15th Aug, 2004 at 09:02:08pm
yep agree with alex box out mate no longer a series, but still 1.3 turbo.
126 Posts Member #: 244 Advanced Member |
16th Aug, 2004 at 10:02:01pm
which gear does that retention ball and spring behind the drive shaft output flange control? Speedster turbo under construction |
17th Aug, 2004 at 09:19:20am
yes I seem to remember that is the detent for 4th gear. worth a try before you rip the engine and box to bits
18th Aug, 2004 at 02:53:20pm
Where exactly is this guys? What would I check for?
18th Aug, 2004 at 08:19:53pm
it is behind one of the driveshaft output flanges on the gear selector shaft side. The Metro Turbo haynes manual says it can be a cause of jumping out of gear (also lists selector forks, bellcrank lever, selector shafts or interlock spool, weak or broken syncro hub springs, worn gears and/or syncro sleeves)
18th Aug, 2004 at 08:22:32pm
another check is that the selector remote has enough travel to engage the gear fully. Unlikely as there is no adjustment but if it is worn??? Speedster turbo under construction |
