| Home > General Chat > K1100 / 1430cc ??? | |||||||
19th Aug, 2008 at 10:21:50pm
Just a quick question, a friend of mine may have a MED built 1430 bottom end forsale.
Edited by cossierick on 19th Aug, 2008. |
19th Aug, 2008 at 11:18:14pm
oooo that would be tastey! |
20th Aug, 2008 at 05:37:41am
As anyone can tell you,size matters ! |
20th Aug, 2008 at 06:27:45am
head gasket could possibly be an issue, but not a big one I think. So I would say go for it. |
20th Aug, 2008 at 10:24:39am
Dooo iiiittt...and slap a turbo on for good measure! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
20th Aug, 2008 at 11:19:18am
You can doo it! Rip his facking head off! |
20th Aug, 2008 at 12:59:24pm
yeah, why don't i go eat some hay. i can make things out of clay, or lay by the bay, i just may. whad dya say?
20th Aug, 2008 at 06:43:52pm
Jackass!! |
20th Aug, 2008 at 08:13:59pm
So is that a yes then ?
![]() 552 Posts Member #: 300 Post Whore Cumbria |
20th Aug, 2008 at 10:18:00pm
Happy Gilmore!
On 20th Aug, 2008 joeybaby83 said:
yeah, why don't i go eat some hay. i can make things out of clay, or lay by the bay, i just may. whad dya say? Here for the craic..
29th Oct, 2013 at 10:25:27pm
Quick thread dig up !!!
![]() 265 Posts Member #: 10512 Senior Member whitby, north yorkshire |
29th Oct, 2013 at 10:38:52pm
ive seen MED do pistons already cut for 16v heads |
29th Oct, 2013 at 10:45:16pm
On 29th Oct, 2013 afrance2905 said:
ive seen MED do pistons already cut for 16v heads Yes I no they do but not for a 1430 !! Rick |
29th Oct, 2013 at 10:46:36pm
I'm sure it would be fine, especially with shallow cut outs. Sprockets old engine only looked nibbled, as does Philc's On 7th Oct, 2010 5haneJ said:
29th Oct, 2013 at 11:24:18pm
Short height with cutouts and dish Drives
30th Oct, 2013 at 06:58:08am
I believe the piston crown thickness is the same as a 1380 piston, just the pin is higher. Id call Steve or Lee at MED, they will give you a frank answer I seriously doubt it! |
30th Oct, 2013 at 07:01:46am
sounds like a weapon! |
30th Oct, 2013 at 11:54:34am
You can get away with the bare minimum on the size of the cut outs if you machine the pistons individually for each cylinder. The cutouts on the MED pistons are fantastically huge because they will fit in any bore and are probibly deeper too On 26th Oct, 2004 TurboDave16v said:
30th Oct, 2013 at 07:19:30pm
A quick call to med this morn confirmed what paul has said , that the pin it just higher up the piston.
, plus 1430 is just long stroke 73.5mm. You can still use normal height pistons with a certain rod. Wolfie had a stroked turbo 1355 iirc +40 with same stroke as yours
