Home > General Chat > OT rubber block
i need some white rubber block 2cm thick approx 10cm x 10cm would do to cut to make some mountings, or some info on making some rubber moulded blocks
any info you guys can help with?
graemec
Member #: 1424
Carnforth, Lancs
There's this stuff (available in 3 different hardnesses):
http://www.frost.co.uk/item_Detail.asp?pro...t=Miscellaneous
cheers
ive bought loads from frost over the years and never thought of contacting them
baaaaaaaahahahahaha
had a search and found this
http://www.dildo-rado.co.uk/Mould-your-own-kits.php
XXX not work friendly XXX
Edited by wolfie on 20th Aug, 2008.
Nicky
Member #: 333
Tadley, Hampshire
Hmm, chocolate cock... lol.
Turbo Shed
Member #: 30
Epsom, Surrey
Wolfie, when you found that site did you use google? only, google keeps a history of what you normally search for and any further searches are linked to old searches. i did a search for moulded rubber blocks and couldnt find this site.......................
Mini_Andy
Member #: 432
no he was searching 'make your own dildos'
mini93
Member #: 2017
Warwick.
hahaha! cock candle and glow in the dark one
David.
try rubber moulding kit
*tongue*
