Home > Technical Chat > How to remove studs from exhaust manifold
MrTurbo
Member #: 814
Utrecht, The Netherlands
I am finalising my turbo Mini (pics of the whole restauration and build will follow soon)!
But.... I need to remove the studs from the exhaust manifold (manifold to turbo) to be able to flatten the manifold to turbo joint. The studs are really tight, I ve already tried WD40 for a few weeks and heating the manifold, but no luck...
Any ideas??
Thanks!
a stud extractor?
yeah thats your best bet mate.
something like this:
http://www.machinemart.co.uk/shop/product/...d-extractor-set
i would probably advise something of good quality with things like this though besuse they will give a better grip on the studs.
usally one! ? .... or 2 studs shear in,
the worst case is helicoil these to 5/16" unf ................. if you drill them out spot on ...... *surprised*
job done! i can do this for you of you wish ?
please PM me
Edited by BENROSS on 21st Aug, 2008.
Mini_Andy
Member #: 432
2 nut method, will take you 2 minutes!
Edited by Mini_Andy on 24th Aug, 2008.
eskynation
Member #: 3490
new zealand. land of the kiwi bird
2 stud method as above
mini93
Member #: 2017
Warwick.
2 stud :S you mean lock 2 nuts locked together and undo? works well before for me..if you dont require the stud again obviously put a nut on there and weld it on and undo that way, obviously no chance of nut slippage then
David.
Yep 2 nuts locked together, plenty of localised heat (only heat around the stud and not the stud itself). *wink*
MrTurbo
Member #: 814
Thanks for all the info. My neighbour happened to have a stud extractor. With a lot of localised heat we finally got them out without damage to the studs or manifold.
